Pressure regulator
Ralph F
Topic author - Posts: 167
- First Name: Ralph
- Last Name: Fitz-Gerald
Pressure regulator
I have a speedster with reel rotary oil and looking for a pressure regulator.
Les Schubert
- First Name: Les
- Last Name: Schubert
Re: Pressure regulator
Are you actually pressuring the bearings. If so then perhaps look at air pressure relief valve.
Craig Leach
- First Name: craig
- Last Name: leach
That looks like a Oberdorfer brass gear pump they can be purchased with a adjustable relief valve built in. You maybe can buy just the head new?
The grease zerks indicate it could also be a Dayton. Craig.
