How much clearance?
michaelb2296
First Name: Michael
Last Name: Bunner
* REQUIRED* Type and Year of Model Ts owned: 1912 Torpedo Roadster 1917 Smith Form-a-Truck
How much clearance?
Post by michaelb2296 » Wed Jun 19, 2024 7:00 pm
How much clearance should there be between the rod cap and the crankshaft lobe? Skat crank has tight tolerances!!! Old cranks dont have this issue… lots of slop between journal lobes.
Kerry
Last Name: van Ekeren
Re: How much clearance?
Post by Kerry » Wed Jun 19, 2024 7:16 pm
Ford specs are the crank is 1.505" and rod is 1.5" wide.
michaelb2296
First Name: Michael
Last Name: Bunner
Post by michaelb2296 » Wed Jun 19, 2024 7:21 pm
How do i sand .0025 off each end? Ford used a big damn file on the caps!
Kerry
Post by Kerry » Wed Jun 19, 2024 7:24 pm
Is the rod turning or binding?
michaelb2296
First Name: Michael
Last Name: Bunner
Post by michaelb2296 » Wed Jun 19, 2024 7:27 pm
Nope! New babbit. Not turning… super tight but does fit around the journal
Kerry
Post by Kerry » Wed Jun 19, 2024 7:58 pm
OK, usually it is the fillet cut that is tight, not cut deep enough to clear the fillet on the edge of the crank journal, but if you think it is too wide then rub the rod on a flat piece of glass with a sheet of about 320 sand paper. Run the rod bearing in with time saver.
Joe Bell
First Name: Joe
Last Name: Bell
Post by Joe Bell » Wed Jun 19, 2024 8:32 pm
I would rather have a large radius than a small one, less chance of breakage.
Last Name: Tannehill
Board Member Since: 2002
Post by JTT3 » Wed Jun 19, 2024 9:28 pm
Amen Joe. As stated time saver will be your friend in fitting the rods on the journal, yellow 60 grit
