ANCO Timer Lube
Topic author - Posts: 127
- Last Name: Dow
ANCO Timer Lube
What does everyone use for non conductive lube for their ANCO timers? I've used a blob of Vaseline for years with no problems. Is there something better?
Re: ANCO Timer Lube
I believe this is a type of "high pressure" lube - it's what I use - https://www.modeltford.com/item/3221LUB.aspx
- Last Name: Dow
Re: ANCO Timer Lube
I wonder how this stuff's properties differ from Vaseline......
Re: ANCO Timer Lube
Vaseline was certainly around during the Model T era. Haven't I seen I seen a published recommendation to use it on a T? Ford? Fahnestock? Gasoline Alley?
