Location of the Pistonrings
ABoer
First Name: Anthonie
Last Name: Boer
* REQUIRED* Type and Year of Model Ts owned: 1912 touring 1923 roadster 1925 pickup
Post by ABoer » Thu Jul 18, 2024 9:57 am
Hi ;
Some time ago I read on the Forum about the location of the Pistonrings .
But I can't find it back .
I hope you can help me .
Thanks !!
Toon
Re: Location of the Pistonrings
Post by Mark Gregush » Thu Jul 18, 2024 12:58 pm
If you mean where the slits are when installing, they would be in 3rds. When the engine is running the rings do not remain stationary in the grooves so do not stay in the same position, they rotate in the grooves.
Or are you asking about which is the top/bottom the ring itself?
Some does not matter, some it does. Generally, on the compression rings if there is no bevel on one of the outside edges, it can go either way. If there is a bevel, that should be the top edge.
Post by TRDxB2 » Thu Jul 18, 2024 1:12 pm
Hi ;
Thanks !!
Toon
Were you looking for something like this https://courses.washington.edu/engr100/ ... 0Rings.htm
piston rings.png (189.43 KiB) Viewed 1469 times
ABoer
Last Name: Boer
Post by ABoer » Thu Jul 18, 2024 1:53 pm
Mark G.
Sorry , I was not clear enough.
What I mean is : where are the slits when installing ?
Toon
big2bird
First Name: Jeffrey
Last Name: Hausey
Post by big2bird » Thu Jul 18, 2024 2:11 pm
120* apart.
This we used to call "Thirding the rings."
They won't move.
Kerry
Last Name: van Ekeren
Post by Kerry » Thu Jul 18, 2024 4:32 pm
Easy to remember, the ring gap goes with in line with the wrist pin then the next 180 with the pin and again another 180 for the oil, never have the gaps on the thrust sides of pistons.
