Starter wireing diagram help needed.
Topic author - Posts: 701
- Last Name: Seress
A friend gave me a starter, working well but full of mud.
I took it apart to clean it but forgot where the two field wires were hooked to.
Can someone enlighten me as to where the two field wires are supposed to be hooked up!
Thank you in advance. Frank
- Last Name: Hatch
Re: Starter wireing diagram help needed.
Service manual under starter repair.
- Last Name: Tannehill
Deleted to not confused anyone
This helps on soldering https://modeltfordfix.com/repairing-a-c ... r-problem/
The two field winding pigtails are connected to the two insulated (from the brushplate) brush holders.
If you follow that rule it is impossible to connect them incorrectly.
Ron Patterson
Ron Patterson
- Last Name: Seress
Gentleman, great advice, Franks data I cannot open.
As you can see from my picture, I have a situation. What should I do next, my starter does not match the diagram above. Do I cross the leads?
Leads do not get crossed in a starter.
1) I doubt you could & reach the brush holders. 2) Both wires are tied together electrically, so it wouldn't matter.
JTT3's picture is for a generator, not a starter.
Also, the mica does not get cut back on a starter commutator.
See the service manual.
- Last Name: Seress
Thank you John. Now to my original question. Where do I place the two field connection wires, to which carbon brush?
For the second time! The two field winding pigtails connect to the two insulated brusholders on the brusplate (NOT the two brusholders without insulators and are grounded to the brushplate)
If you follow this rule it is inpossible to connect them to the brusholders incorrectly.
Ron Patterson
Ron Patterson
The diagram posted above is for a generator filed winding NOT a starter field winding.
Attached is a photo of the brushplate inside the brushcap and you can see the two insulated brusholders.
Sorry about that folks I mistakenly was trying to help Frank out with a quick diagram so took a picture from the Starter section of the MTFCA BOOK THE Electrical System, page 22, without noticing that the picture was of a generator
- Last Name: Golden
Something about that starter does not look right!
- Last Name: Jablonski
What would that be? James?
Don't know why you couldn't open the link by just clicking on it.Sarikatime wrote: ↑Mon Jul 29, 2024 2:28 pmGentleman, great advice, Franks data I cannot open.
As you can see from my picture, I have a situation. What should I do next, my starter does not match the diagram above. Do I cross the leads?IMG_0825.jpeg
