Starter wireing diagram help needed.
Sarikatime
Last Name: Seress
Post by Sarikatime » Sun Jul 28, 2024 10:28 am
A friend gave me a starter, working well but full of mud.
I took it apart to clean it but forgot where the two field wires were hooked to.
Can someone enlighten me as to where the two field wires are supposed to be hooked up!
Thank you in advance. Frank
Last Name: Hatch
Re: Starter wireing diagram help needed.
Post by Dan Hatch » Sun Jul 28, 2024 11:04 am
Service manual under starter repair.
Last Name: Tannehill
Post by JTT3 » Sun Jul 28, 2024 11:35 am
Deleted to not confused anyone
Post by TRDxB2 » Sun Jul 28, 2024 11:43 am
Ron Patterson
Post by Ron Patterson » Sun Jul 28, 2024 2:38 pm
The two field winding pigtails are connected to the two insulated (from the brushplate) brush holders.
If you follow that rule it is impossible to connect them incorrectly.
Ron Patterson
Sarikatime
Last Name: Seress
Post by Sarikatime » Mon Jul 29, 2024 2:28 pm
Gentleman, great advice, Franks data I cannot open.
As you can see from my picture, I have a situation. What should I do next, my starter does not match the diagram above. Do I cross the leads?
Hope this helps. Note the positive & negative configuration of the field coils.
Post by speedytinc » Mon Jul 29, 2024 2:37 pm
Leads do not get crossed in a starter.
1) I doubt you could & reach the brush holders. 2) Both wires are tied together electrically, so it wouldn't matter.
JTT3's picture is for a generator, not a starter.
Also, the mica does not get cut back on a starter commutator.
See the service manual.
Sarikatime
Last Name: Seress
Post by Sarikatime » Mon Jul 29, 2024 2:46 pm
Thank you John. Now to my original question. Where do I place the two field connection wires, to which carbon brush?
Ron Patterson
Post by Ron Patterson » Mon Jul 29, 2024 3:50 pm
For the second time! The two field winding pigtails connect to the two insulated brusholders on the brusplate (NOT the two brusholders without insulators and are grounded to the brushplate)
If you follow this rule it is inpossible to connect them to the brusholders incorrectly.
Ron Patterson
Ron Patterson
Post by Ron Patterson » Mon Jul 29, 2024 3:53 pm
The diagram posted above is for a generator filed winding NOT a starter field winding.
Attached is a photo of the brushplate inside the brushcap
and you can see the two insulated brusholders.
Post by JTT3 » Mon Jul 29, 2024 6:08 pm
Sorry about that folks I mistakenly was trying to help Frank out with a quick diagram so took a picture from the Starter section of the MTFCA BOOK THE Electrical System, page 22, without noticing that the picture was of a generator
J1MGOLDEN
Last Name: Golden
Post by J1MGOLDEN » Mon Jul 29, 2024 8:18 pm
Something about that starter does not look right!
Moxie26
Last Name: Jablonski
Post by Moxie26 » Mon Jul 29, 2024 8:35 pm
What would that be? James?
Post by TRDxB2 » Tue Jul 30, 2024 1:11 am
Don't know why you couldn't open the link by just clicking on it.
