Brass carb float sealer???
Marshall V. Daut
First Name: Marshall
Last Name: Daut
Post by Marshall V. Daut » Sun Jul 28, 2024 11:06 am
I have soldered a couple questionable spots on the Kingston L-4 carb's float that I have been trying to save. I would like to seal the entire float, encase it, as it were. Is there a gas-resistant sealer that will do this, such as a marine spar varnish?
If I cannot save this float - which sinks like a rock - why wouldn't a float from an L-2 Kingston work? The L-4 float is not being made, but the L-2 float is. The bodies and bowls appear to be the same. Is the hinged area different between these floats that makes using the L-2 float in this L-4 carb not possible?
Marshall
Last Name: Wrenn
Re: Brass carb float sealer???
Post by TWrenn » Sun Jul 28, 2024 11:31 am
This oughta work.
Post by speedytinc » Sun Jul 28, 2024 11:43 am
Line-a-tank. Gas tank sealer would work. I have used it on cork floats.
Should work fine on a brass float also.
Post by TRDxB2 » Sun Jul 28, 2024 12:08 pm
Marshall
Ron says you can https://modeltfordfix.com/rebuilding-th ... arburetor/
Last Name: Tannehill
Post by JTT3 » Sun Jul 28, 2024 12:22 pm
On old cork or or brass floats that were leaking I mix a 50/50 solution of acetone & Red Kote (found at most part stores) which I also use on gas tanks. The key is to let it dry until there is very little smell. Another tip is with that same mix I’ll coat the inside of the carburetor fuel bowl & at times the part of the carb body that sits in the fuel bowl. I’m cheap so I run 80/15 corn gas when I know I’ll be driving a lot. Rational for coating those parts is that it seals the metal from rusting. Your mileage may vary.
m_p_dean@yahoo.com
First Name: Maurice
Last Name: Dean
* REQUIRED* Type and Year of Model Ts owned: 1917 Touring Car
Post by m_p_dean@yahoo.com » Sun Jul 28, 2024 6:01 pm
Who makes L2 floats?
Post by TRDxB2 » Sun Jul 28, 2024 6:37 pm
Don't know who makes them but Lang's, SnJ & Snyder's sell them
l2 float.png (101.62 KiB) Viewed 2686 times
Last Name: Hatch
Post by Dan Hatch » Sun Jul 28, 2024 7:06 pm
Why not just get another L4 float? Buy a core carb. Dan
Marshall V. Daut
Last Name: Daut
Post by Marshall V. Daut » Sun Jul 28, 2024 11:36 pm
The float in this carb was and still is a mess, despite best efforts to resuscitate the cadaver : it still leaks and the adjusting tang broke in two and fell off. The rest of the carb is pretty good, however. Because of the broken tang, buying a repo modern material float won't help. I would gladly buy a good used L-4 float or even a complete L-4 carb with a good float to use as spare parts. I know it's not the best Model T carb available, but it is correct for this 1919 Centerdoor.
Marshall
Post by Mark Gregush » Mon Jul 29, 2024 2:53 am
Something to remember and think about, every bit of solder or coating put on that brass float changes it buoyancy, making it heaver. ;)
Last Name: Wrenn
Post by TWrenn » Mon Jul 29, 2024 7:57 am
Good thought! Definitely have to readjust the float setting.
Last Name: Hatch
Post by Dan Hatch » Mon Jul 29, 2024 3:04 pm
See my ad in classified.
Corey Walker
First Name: Corey
Last Name: Walker
Post by Corey Walker » Tue Jul 30, 2024 6:38 pm
Here’s what an L2 float would look like in an L4. A little too big. If you’re good at soldering you can put an L4 hinge on an NH float. Just remove the NH hinge and solder it to the side without the recess where the NH hinge goes.
