New Bands
South Park Zephyr
Last Name: Francis
* REQUIRED* Type and Year of Model Ts owned: 22 Runabout
Board Member Since: 2022
New Bands
Post by South Park Zephyr » Mon Aug 05, 2024 7:19 pm
We recently had our overnight tour here in St. Louis. My daughter, Hailey, had band problems again. Some may remember last fall her 23 touring had a brake band fail and it put her on the sag wagon. This year the Sandanavia bands she had found from a local online post went south as well. They unfortunately were the infamous “tar babys”.
My question is, since good Scandinavia band are no longer being produced, what should we use?
I’ve heard good and bad about Kevlar, what else is available though?
She is pretty good at driving her car, but I’m not up for replacing drums if she were to break one due to misadjusted Kevlar.
I know that they will be many points of view about this, I’m only trying to find a forgiving solution to her problem.
Thank you,
Scott
Moxie26
Last Name: Jablonski
Re: New Bands
Post by Moxie26 » Mon Aug 05, 2024 7:51 pm
Wood band liners. Inherently soft on drum wear.....new band springs greatly help with adjustments.
Re: New Bands
Post by Steve Jelf » Mon Aug 05, 2024 8:19 pm
Correctly adjusted and correctly driven, kevvies are fine. Bad habits (riding pedals and otherwise letting drums slip excessively) are not fine.
Last Name: Kuehn
Re: New Bands
Post by John kuehn » Mon Aug 05, 2024 9:11 pm
Wrong or bad driving habits will wear out cotton bands or wood and bad driving habits with Kevlar will crack drums. New band springs will definitely help to keep the linings off the drums. Slipping the clutch drum will definitely wear the low speed band.
