Need some help identifying the year of these pliers
Topic author - Posts: 1865
- Last Name: Tannehill
Putting together a tool roll & I can’t find the years for these pliers. Note it has the T/W & Ford script but does not have the handle with the flathead screw driver.
Re: Need some help identifying the year of these pliers
If I had my desktop computer I would consult the model T Encyclopedia, which often settles such questions. That may or may not apply to the truncated online version.
- First Name: K
- Last Name: Burket
As Mr Jelf mentions, the online encyclopedia gives some insight stating:
1921-1927
T1903 pliers modified to have screwdriver blade on one handle and the T1902 screwdriver was dropped. Otherwise the same as 1920.
https://www.mtfca.com/encyclo/S-T.htm#tool
The thumb drive or CD version of the encyclopedia may give you more specifics.
According to Roger Karlsson’s comment in this old post, ford script wasn’t added to tools until 1919 time frame.
http://www.mtfca.com/discus/messages/80 ... 1253369726
1921-1927
- First Name: Michael
- Last Name: Deichmann
That narrows it is to 1920 +/-
Ford Model T 1914 Touring
An earlier post had similar pliers, no screwdriver end. The mfg markings are T. Williams, English co. Made for English Fords.
The 2nd photo version without Made in England could have been modified to remove that country legend.
Ford T pliers believed to have screwdriver tips early on, with later versions having tip angle and length and thickness changed 1920 when the wood handle screwdriver was deleted from the tool kit.
Have a copy of the Record of Change for the T-1903. Interesting is that the 'screwdriver tip' was on the pliers perhaps prior to 1913, so the pliers likely had that tip on one handle for long time, even when the T-1902 screwdriver was part of the tool kit.
Details:
2-2-1915 change screwdriver tip to 1/32" thick at end from 3/64"...specified bevel length
12-19 1916 specified Ford script
10-11- 1920 change bevel of end of screwdriver tip to 7/8" from 3/8"...specified end to be hardened ....this change made to enable pliers to replace screwdriver in the tool kit...screwdrivers on hand to be used up.
Made In England script Ford pliers:
Details:
I'd echo Dan's opinion. The Transue Williams forge mark common on many early Ford T parts has the T superimposed over the W. This one is different. The overall shape is like those used in English production for later cars.
Thanks all, now the question, how’d it get here ha
- Last Name: Hatch
John that is easy, waded cross the River at Eagle Pass. Just like all the rest.
