If you need help logging in, or have question about how something works, use the Support forum located here
Support Forum
- Last Name: Hjortnaes
Post
by DHort » Thu Aug 22, 2024 6:10 pm
- 2931886s.jpg (6.56 KiB) Viewed 3095 times
How do you attach this item to your low speed adjusting part, and what should it look like when finished?
Thank u
Post
by RajoRacer » Thu Aug 22, 2024 7:08 pm
Not any Ford part I've seen ??????????
Post
by John kuehn » Thu Aug 22, 2024 7:30 pm
The nut adjuster didn’t look right to me either. For curiousity I looked this up and Lang’s sells these for easier adjusting purposes. Maybe a copy of and older aftermarket part?
https://www.modeltford.com/item/3420EX.aspx
New one for me.
Post
by DanTreace » Thu Aug 22, 2024 8:05 pm
DHort wrote: ↑Thu Aug 22, 2024 6:10 pm
Thank u
Believe that extension threads over the end of the flats on the low speed screw, like a cap, to present a hex face for turning.
Maybe useful, if perhaps one old has rounded off flats, but the regular flats help to control half twists at a time for adjustment, maybe some like a hex for using a box wrench or socket
DanTreace on Sat Aug 24, 2024 9:22 am, edited 1 time in total.
Post
by speedytinc » Thu Aug 22, 2024 8:10 pm
The way I read Langs description - it replaces the jam nut making it easier to get a wrench on, not so close to the HH casting.
Post
by DanTreace » Thu Aug 22, 2024 8:23 pm
speedytinc wrote: ↑Thu Aug 22, 2024 8:10 pm
That is likely the use, from the photo didn't see a thru hole, figured it was a cap.
Makes sense as sometimes that lock nut is hard to move, as usually only a portion of the open end wrench can grasp it, due to the concave opening there.
jab35
- Last Name: Bartsch
Post
by jab35 » Thu Aug 22, 2024 8:42 pm
From the Lang's part description: Slow speed adjusting nut, extended. Style of nut that is extended to make adjusting with a wrench easier.
Post
by RajoRacer » Thu Aug 22, 2024 9:55 pm
So - that replaces the Ford locknut ?
Post
by Allan » Thu Aug 22, 2024 10:23 pm
That nut would be a big help when adjusting reverse gear on RHD cars. The original jam nut is very close to the rear face of the bell in the housing. You need a thinned down socket/ring spanner to access it.
Post
by DanTreace » Fri Aug 23, 2024 8:08 am
RajoRacer wrote: ↑Thu Aug 22, 2024 9:55 pm
Yep, should have looked close at the part number Lang’s assigned.
T-3420 is the adjusting lock nut. Lang’s item number is 3420EX for the special extended lock nut.
Jim Eubanks
- First Name: Jim
- Last Name: Eubanks
Post
by Jim Eubanks » Fri Aug 23, 2024 8:44 am
A thick washer works just fine.
Post
by Original Smith » Fri Aug 23, 2024 6:10 pm
Don't use that crap. Nothing is easier than Ford's method, which I've been doing for 60+ years!
Post
by Allan » Fri Aug 23, 2024 8:09 pm
Larry, it is not uncommon to find the reverse gear adjuster locknut on a RHD car butchered by the use of a cold chisel to lock it on the adjuster. Far from being "crap", this little gem would solve that problem. Obviously, your limited experience on LHD cars differs.
- First Name: Keith
- Last Name: Townsend
Post
by KWTownsend » Fri Aug 23, 2024 8:16 pm
Use the 15/16" spark plug wrench to loosen and tighten the original jam nut.
Post
by John kuehn » Fri Aug 23, 2024 8:21 pm
As others mentioned getting a fit to the original nut didn’t always happen. I’ve got a few of the low speed adjusters that the nut were either the shoulders were getting worn down or rounded down. Putting a washer or two under the nut or the longer adjuster nut makes for a better wrench fit. I don’t know if Ford made a tool for that purpose but I use a fairly thin box end wrench for that purpose among others.
Post
by RajoRacer » Fri Aug 23, 2024 9:41 pm
The later Ford band ratchet tool included the 15/16" end opposite the ratchet end - great tool !
