Part usage Sought
hddennis
First Name: Howard
Last Name: Dennis
Part usage Sought
Post by hddennis » Mon Sep 02, 2024 11:29 pm
Found this set of all brass air horns at our local antique mall and wonder what they were used on. Did early trucks use something like this?
Thanks for any help,
Howard Dennis
Novice
First Name: Jim
Last Name: Davis
Re: Part usage Sought
Post by Novice » Tue Sep 03, 2024 12:38 am
May have come off a diesel locomotive.
varmint
First Name: Vernon
Last Name: Worley
Post by varmint » Tue Sep 03, 2024 7:11 am
With all the parts appearing to be brass, not steel, I think it may be powered by steam instead of air.
Wrong shape for a river boat horn.
Vern (Vieux Carre)
Post by TXGOAT2 » Tue Sep 03, 2024 10:27 am
FWIW, I've never encountered a steam horn. All manner of steam whistles were once common, but never a steam horn that I know of. I'd guess these are air or vacuum operated horns for some kind of vehicle. Diesel and electric locomotives used air horns, and they can still be found for sale. Search: "Locomotive air horn"
Post by TRDxB2 » Tue Sep 03, 2024 11:13 am
Did a bit of searching the web to see if the construction of the horns might point to an answer.
-The aesthetics of the base would lend itself to a train or truck. not fancy enough for a motor boat & larger boats had deeper sounding tones.
Air horns also used by emergency vehicles and in sports arenas too
-The short length of the trumpets would give a higher pitch sound. From the internet: Originally, diesel locomotives were equipped with truck horns. After an accident in which a driver mistook a train for a truck, the need for a unique-sounding train horn became clear. Consequently, North American trains now have at least two horns with different tones forming the airhorn, that sound simultaneously, creating a harmonic interval or chord. Currently Train horns have a deeper sound than truck horns.
-The fitting for the air hose connection may be a clue. Looks like its for a hose. That may make it more likely to be for a truck than a train. From the internet: In trucks and buses, the air horn is powered with compressed air from the vehicle's air brake system.
I'd hook it up to a compressor to see what sound it would make (wear air sound protection).
Post by Mark Gregush » Tue Sep 03, 2024 4:02 pm
If polished up would look just fine on a boat! :)
mtntee20
First Name: Terry & Sharon
Last Name: Miller
Post by mtntee20 » Tue Sep 03, 2024 4:12 pm
The small diaphragms, tone adjustments, and bell size are very indicative of truck air horns. Air pressure and tone adjustment would give a wide range of sound options.
hddennis
First Name: Howard
Last Name: Dennis
Post by hddennis » Tue Sep 03, 2024 4:23 pm
Thanks guys for all your help. Once again you guys come thru! Wasted my time over at AACA site, 105 views and not one response! I may just quit going there at all.
Howard Dennis
South Park Zephyr
Last Name: Francis
* REQUIRED* Type and Year of Model Ts owned: 22 Runabout
Board Member Since: 2022
Post by South Park Zephyr » Tue Sep 03, 2024 8:46 pm
Way too small for a railroad locomotive. Im thinking a boat might be a good guess
