As The Saying Goes : Two Heads Are Better Than One
Topic author - Posts: 1476
- First Name: Terry
- Last Name: Woods
I picked up these two period, aftermarket, cast iron heads today, cheap.
- First Name: craig
- Last Name: leach
Re: As The Saying Goes : Two Heads Are Better Than One
Nice find.
Craig.
Craig.
Both are high compression heads which should raise your horsepower. But only one can be used per engine!
- First Name: Terry
- Last Name: Woods
Norm, I figured someone would say 'only one per motor', but these two heads and my other two heads (a Zajicek and a Prus) will go on FOUR different motors that I have. NOW, if I only had a Haibe head, I'd have a 'trifecta'.Norman Kling wrote: ↑Thu Sep 19, 2024 9:56 pmBoth are high compression heads which should raise your horsepower. But only one can be used per engine!![]()
- Last Name: House
Good score Terry, I ran a Giant Power Head on a ‘23 touring that I sold. It greatly increased performance. Same as the Waukasha Ricardo presently on my ‘19 sedan. Congrats !!
This is the patent that both high compression heads were licensed under.
And the key info for this patent by the inventor:
- First Name: Terry
- Last Name: Woods
Interesting. Thanks, Dan.
Dan, can you translate what was being stated in the two last paragraphs? To me, it looks like he was trying to blind them with science.
Here is link to the patent so you can read the details, and use the patent drawing item numbers to understand the claims.
But generally the claim is the secondary channel or flame path to the thinned cylinder inside combustion chamber.
https://patents.google.com/patent/US164 ... us+1645423
