Looking for a used steering arm for another project. Ball can be worn down a bunch, actually just need the ball its self. Please contact me. Thank you in advance.
Tom
steering arm
Topic author - Posts: 113
- First Name: Tom
- Last Name: VanMeeteren
- * REQUIRED* Type and Year of Model Ts owned: 1911 touring 1923 touring
Re: steering arm
Tom, if all you need is a ball, the tie rod balls available from the vendors are the same size. I use them to replace the worn balls on early pitman arms.
