Looking for a parking brake arm for the hand brake shaft for my 26.
Reno Speedster
First Name: Morgan
Last Name: Blanchard
* REQUIRED* Type and Year of Model Ts owned: 1926 Model T Speedster Project, 1922 Runabout Pickup
Post by Reno Speedster » Sun Sep 22, 2024 7:26 pm
I am looking for a good parking brake arm (the one opposite the hand brake lever) for my 26. I have attached a couple of pictures of what I am after. The large hole is 3/4 inch dia. and it is held on by one pin. If you have one in good shape you would be willing to part with (particularly with holes that are round) please send me a pm.
Karl Von Neumann
First Name: Karl
Last Name: VonNeumann
Board Member Since: 2022
Re: Looking for a parking brake arm for the hand brake shaft for my 26.
Post by Karl Von Neumann » Sun Sep 22, 2024 9:59 pm
I've got the whole assemblys if that helps?
Reno Speedster
First Name: Morgan
Post by Reno Speedster » Sun Sep 22, 2024 11:04 pm
Karl,
I will keep that in mind.
Walt Wise
First Name: Walt
Last Name: Wise
Post by Walt Wise » Mon Sep 23, 2024 5:42 am
You may want to check out the below listing on Ebay. I "think" it includes the part you are looking for and probably another that you aren't?
https://www.ebay.com/itm/256642815117?_ ... R8Cm6uPDZA
No connection to the ad whatsoever...just trying to help...
The auction ENDS in about 7 hours and no bid yet...
First Name: Austin
Last Name: Farmer
Post by 1925 Touring » Mon Sep 23, 2024 11:53 am
Bob's Antique Auto parts in Rockford carries lots of old oroginal parts, im sure he would have one.
Goes by FATMAN on the forum.
Post by Allan » Tue Sep 24, 2024 12:19 am
Morgan, if it is any help, I braze weld the hole completely shut and then redrill the bronze to the standard clevis pin size. That means i usually get a pin running in bronze, just like it had been bushed.
