Wanted - Oil Pan for 1925 Roadster
wmscottsutherland
Last Name: Sutherland
Post by wmscottsutherland » Mon Oct 21, 2024 1:36 pm
All,
I'm looking for an oil pan in good useable shape. I'm in Cheyenne so from Denver north would be a reasonable driving distance.
Please let me know.
Scott
Last edited by wmscottsutherland on Tue Oct 22, 2024 11:19 am, edited 2 times in total.
big2bird
First Name: Jeffrey
Last Name: Hausey
Re: Wanted - Oil Pan 3 dip for 1925 Roadster
Post by big2bird » Mon Oct 21, 2024 3:37 pm
Why not a 4 dip?
Last Name: Hatch
Post by Dan Hatch » Mon Oct 21, 2024 4:15 pm
Do your self a favor, get a 4 dip.
But what ever you get, put it on a pan jig before you use it.
wmscottsutherland
Post by wmscottsutherland » Mon Oct 21, 2024 5:46 pm
Big2bird,
Because a 3dip was on it originally. Not because of my experience as I'm just barely past novice stage.
Scott
Post by RajoRacer » Mon Oct 21, 2024 10:38 pm
If it's a true '25, it would have had a 4-dip c.c. from the factory.
wmscottsutherland
Re: Wanted - Oil Pan 4 dip for 1925 Roadster
Post by wmscottsutherland » Tue Oct 22, 2024 6:08 am
RajoRacer,
It is a true 25. The block is the only thing that I know was original.
So I need a 4 dip.
Scott
Adam
First Name: Adam
Last Name: Doleshal
Post by Adam » Tue Oct 22, 2024 8:18 am
Four dip pans are weaker than 3 dip pans. If you don’t have provisions to bolt the top of the transmission cover to the back of the block (lugs on the hogshead and bolt holes on the back of the block water jacket like ‘26 & ‘27 had), then you really should stick with the 3 dip pan for better rigidity. Ford made a number of “fixes” to the flexibility issue with the four dip pans after they initially began using them. The final solution was bolting the hogshead to the back of the block to solve the problem.
Unfortunately, people see the four dip pans as “ better” because they allow easier access to the fourth connecting rod but are usually unaware of the tradeoff in terms of flexibility and longevity issues.
wmscottsutherland
Re: Wanted - Oil Pan for 1925 Roadster
Post by wmscottsutherland » Tue Oct 22, 2024 11:21 am
Changed ad to wanted oil pan. :)
Post by RajoRacer » Tue Oct 22, 2024 12:03 pm
I agree with Adam's assessment regarding the rigidity of the 3 dip c.c. - 4 dips are more prone to distortion from front end collisions and frame twisting.
Last Name: Hatch
Post by Dan Hatch » Tue Oct 22, 2024 1:51 pm
Today is brought to you by the words “pan jig”.
Post by RajoRacer » Tue Oct 22, 2024 3:25 pm
Agreed Dan - gotta have all of them verified ! Homemade but totally functional - critical dimensions courtesy of the late Herman Khonke !
big2bird
First Name: Jeffrey
Last Name: Hausey
Post by big2bird » Tue Oct 22, 2024 5:29 pm
It's a roadster, not a sedan or TT. 4 dip will work fine, and is correct.
wmscottsutherland
Post by wmscottsutherland » Tue Oct 22, 2024 6:02 pm
Big2Bird,
You are correct and vey accurate. :)
I changed the want to an oil pan.
Scott
Ken Buhler
First Name: Ken
Last Name: Buhler
Board Member Since: 2012
Post by Ken Buhler » Wed Oct 23, 2024 10:05 am
Interesting that after years of posts about piles going to scrap, that we now see a post wanting a pan in an area so close to Denver, where Henry had a factory. I have been saying for years that we best not think parts are plentiful and everywhere.
Twenty years ago Dave Huson in Berthoud Co. had a lot of parts that he was posting for sale. Some of his pictures showed stacks of pans and blocks. Someone in the area should look into this and make sure they don't go away.
I created a state of the art pan jig that has anchor points and thread driven attachments to push and pull the snout, fourth main, and arms into perfect alignment with minimal need for beating. It also can correct a hump or dip in the pan flange. Shipping of course, is an issue.
Work honestly
Stay true to your word
Get the job done right
DustySpokes
First Name: Edmund
Last Name: Niedzielski
* REQUIRED* Type and Year of Model Ts owned: 1914 Touring, 1922 Mercury Bodied Speedster, 1926-27 Roadsters /Tourings
Post by DustySpokes » Wed Oct 23, 2024 12:38 pm
Sir Kenneth, I will likely give your jig a try next year.
-Dusty from Regina
wmscottsutherland
Post by wmscottsutherland » Wed Oct 23, 2024 1:15 pm
I just talked to Gene French and he referred me to Dave Huson. I found a web site of his modeltcentral.com but it does not allow a message to be sent. The site looks to be untouched for a long time.
If anyone has a way to contact him please PM me.
Scott
wmscottsutherland
Post by wmscottsutherland » Thu Oct 24, 2024 3:34 pm
Still looking. I am batting 0.00% at this time. :)
RecklessKelly
Last Name: Maxson
Post by RecklessKelly » Thu Oct 24, 2024 5:33 pm
Fordbarn T classifieds, a 3 dipper for $25.
big2bird
First Name: Jeffrey
Last Name: Hausey
Post by big2bird » Thu Oct 24, 2024 5:55 pm
Try calling Chaffin.
wmscottsutherland
Post by wmscottsutherland » Thu Oct 24, 2024 8:08 pm
Good news. I got a better phone number for Dave Huson. Spoke with him this evening. He has what I need.
