Camshaft
Re: Camshaft
What year ?
				t-time
- Last Name: Bruto
- * REQUIRED* Type and Year of Model Ts owned: 1914 speedster 1927 coupe
Re: Camshaft
try egge machine in Ca they usually have regrinds outright
				vanco
- Last Name: Van Cott
Re: Camshaft
Steve, my block is early, (9-29-15).
				vanco
Re: Camshaft
Thanks Mark!
- Last Name: Hatch
Re: Camshaft
Use 26/27 to keep from having front bearing knock.
If you were closer I got a 5 gal bucket full.
				Randall strickland
- First Name: Randall
- Last Name: Strickland
Re: Camshaft
kevin pruse has new cams
				Randall strickland
Re: Camshaft
kevin 330 774 7130
Re: Camshaft
I don't have much in late cam cores but have plenty of early BUT Dan H.'s suggestion is worth considering - I believe the new cams are the late style.
				vanco
Re: Camshaft
Dan, Randall and Steve,  Thanks for you advice!!
- First Name: craig
- Last Name: leach
Re: Camshaft
Hi John ,
If you end up with a early cam I have one shim kit left.
