Canadian mufflers
Canadian mufflers
Post by Allan » Mon Nov 11, 2024 9:04 pm
The Canadian 20's mufflers are a little different
Notice the riveted on bracket and separate deflector. Like US production, the ends appear to be pressed with two thicknesses of thinner material. On the front end there is a lair of crescent shaped cut-outs on the small lip that goes to the exhaust pipe. Instead of the rolled in Ridge used on the US exhaust pipes, up to which the muffler end is jammed, the Canadians drilled the pipe and installed a 1/4" cotter pin as a register for the front end cover
I make replacement mufflers like these. The inner pipe is expanded to take the standard pipe. The shoulder created by the expansion is the register for the front cover.
J1MGOLDEN
Last Name: Golden
Re: Canadian mufflers
Post by J1MGOLDEN » Tue Nov 12, 2024 9:53 am
How would you get one to the USA and how much would it cost?
Tadpole
First Name: Tad
Last Name: Glahn
* REQUIRED* Type and Year of Model Ts owned: 1925 Coupe, 1926 TT Closed Cab, 2 1924 Runabouts
Post by Tadpole » Tue Nov 12, 2024 10:11 am
That is a really nice design and fine work by you Allan!
Post by Allan » Tue Nov 12, 2024 5:11 pm
James, I have one boxed ready to go to Bendigo swap meet. i will get a postage estimate on it. The next four will have stainless inner and outer shells, as I had some available at the time.
Allan .
J1MGOLDEN
Last Name: Golden
Post by J1MGOLDEN » Mon Nov 18, 2024 10:14 am
Allan, I would like to buy one.
There probably is not one even left in Canada.
Three of our local club members have Made in Canada cars.
There may be others interested in Canada or the USA.
