Starter drive question
Modeltmike
Last Name: Sleep
* REQUIRED* Type and Year of Model Ts owned: I have 22, 24, 26 coupe, 25 pickup, 23 roadster, 27 touring and 26 Fordson.
Post by Modeltmike » Wed Dec 04, 2024 9:38 pm
I have replaced several starter drives, but haven’t had this happen before. It looks like end simply unscrewed. Nothing broken. I compared to another one like it. I am not sure how it is secured once it screwed back on. How is it secured? I don’t see a pin. I would like to reuse if I can. Thanks [image][/image]
Kevin Pharis
First Name: Kevin
Last Name: Pharis
Re: Starter drive question
Post by Kevin Pharis » Wed Dec 04, 2024 10:13 pm
The cap is screwed on till it bottoms out on the shoulder, then is “staked” into place. Use a hammer and blunt chisel to deform the shaft material outward into the area where the hole is, locking the cap from turning
Post by Allan » Thu Dec 05, 2024 12:14 am
When replacing that sleeve after a rebuild, it needs to land in a different spot so the dumping of the thread occurs elsewhere to the initial dump to be effective. All you need to do is grid a small amount off the back of the sleeve so it winds on just a tad further, making the dumping spot engage with new material.
Post by RajoRacer » Thu Dec 05, 2024 10:49 am
Besides re-staking, I always apply sleeve retaining compound.
