OLD PHOTO - OSHA?.........We Don't Need No Stinking OSHA!!
Topic author - Posts: 1527
- First Name: Jay
- Last Name: Buscio
- * REQUIRED* Type and Year of Model Ts owned: 1913 speedster 1915 roadster pickup 1915 touring, 1927 speedster
Re: OLD PHOTO - OSHA?.........We Don't Need No Stinking OSHA!!
Note that there is a chain hoist still attached to the car. Bolting or nailing an X brace between the two upright timbers to form an "A" frame would add a lot of stability, as would adding a top crossmember chained to the car and a bottom crossmember.
The roof trusses of that building are probably wood, and it may be supporting the weight of many layers of roofing added over many years. It might also have tons of snow on it... and the trusses may have water damage from leaks in the roof. If it's a two-story building, no telling how much weight may be on the second floor.... It may be loaded with car parts and who knows what. On the other hand, the higher the car is raised, the less weight is supported by the hoist, timbers, and whatever the hoist is suspended from.
This almost always works! I've only very seldom dropped a car on my head.
BTW, if the chain broke, the rear wheels would most likely roll, (since they don't appear to be chocked), and the car would roll off of the posts. The obtuse angle of his spreader chain also adds greatly to the tension on it. Oh well, it lasted long enough for the photo anyway.
- First Name: Jay
- Last Name: Buscio
- First Name: Steven
- Last Name: Grant
- * REQUIRED* Type and Year of Model Ts owned: 1920 Open Express, 1922 Centerdoor, 1924 Coupe
That's what they call a two-post lift!
- Last Name: Maxson
If I took out my garage door opener I could pull that one off.
- First Name: Shannon
- Last Name: Helm
So you're saying your username fits you well-- right?!? Just kidding...
- Last Name: Maxson
Setting the rear brakes would be a very good idea. Grease pits are nice... until someone falls in.
- First Name: craig
- Last Name: leach
OSHA we don't need no stinking OSHA!!
Testing to see how the 4th main holds oil. If it runs out the rear axles, the 4th needs repair.
- Last Name: Maxson
The guy with the hat on the right must be the boss man.
- First Name: Art
- Last Name: Mirtes
I worked in a grease pit 60 some years ago. Hated every minute of it. I preferred working on a creeper at that time. I don't have a lift, so creeper it is
Art Mirtes
Art Mirtes
