I am wondering if Ford made different length pitman arms. I am working on a speedster, and have run into a problem with the length of the pitman arm that is on car now.
Fitz
Pitman arm
ModelTWoods
- First Name: Terry
- Last Name: Woods
Re: Pitman arm
Yes they did,and they may have made some with other differences other than length or part number. For instance because of a 26-27 chassis having a lower stance than previous models, the pitman arm was slightly different.
Re: Pitman arm
Check out this earlier post for the differences. https://www.mtfca.com/discus/messages/4 ... 1402824133
Re: Pitman arm
Different front end pieces
- Attachments
- Steering Change Details.jpg (108.25 KiB) Viewed 4074 times
- Drag link.png (162.93 KiB) Viewed 4074 times
Re: Pitman arm
I always mike the ball. Some of them are quite worn.
Re: Pitman arm
No need to mike this T-3547 Steering Gear Ball ArmOriginal Smith wrote: ↑Wed Jan 08, 2025 11:13 amI always mike the ball. Some of them are quite worn.
