Got them. Want to buy Rocky Mountain brake pad only
Topic author - Posts: 701
- Last Name: Seress
On a tour my drivers side rear brake must have been too tight and it got hot and cought on fire.
I need either a Rocky Mountain brake pad or the pad and the metal it is riveted to.
If you have one or know where to get one, please let me know.
The Rocky Mountain Brake Company is not operating at this time and may or may not ever.
Thank you,
Frank Seress
sarikatime@yahoo.com
Eight one eight two Five four six seven nine seven.
Thank you,
Frank Seress
Re: Want to buy Rocky Mountain brake pad only
Mc Master carr sells a great woven replacement. Specify width, thickness & length.
I prefer this material to the hard solid linings as installed originally.
- First Name: Karl
- Last Name: VonNeumann
- * REQUIRED* Type and Year of Model Ts owned: 1916 touring 1927 tudor 1926 hotrod 1913 speedster (project) 1926 coupe (project)
- Board Member Since: 2022
You can buy lining by the foot on ebay
If you are going to reline one shoe, the other should be done with the same material, or you may have different braking forces due to different co-efficients of friction in brake lining materials at the two wheels.
Allan from down under
- First Name: Steven
- Last Name: Grant
- * REQUIRED* Type and Year of Model Ts owned: 1920 Open Express, 1922 Centerdoor, 1924 Coupe
Not to hijack this thread, but what has happened to the Rocky Mountain Brake Co.? Illness, retirement, wildfires, worse?
Thanks.
Steve
Thanks.
Steve
- Last Name: Saylor
I relined my Rockies with the McMaster Carr woven. Stops great but was wearing groves into the drum. 26-27. Removed it and got molded lining from Chaffins. They carry several kinds.
A friend of mine just spoke to Bud's son, apparently Bud has been diagnosed with Dementia but his son intends on continuing the business from what my friend understood.
- First Name: Ralph
- Last Name: Fitz-Gerald
I was able to purchase lining form Langs.
Fitz
Fitz
- Last Name: Seress
Thank you guys for all the information. Finally got linings from Langs.
Wondering which lining you got as the brass wire should not have been hard enough to wear grooves in the drums? Did you not counter sink the rivets, which I could see as being the reason for the grooves. And yes, you can counter sink the rivets on woven lining.
I would not use any type of hard lining on pressed steel drums only cast iron. It has been said over and over again to only use woven lining on that type of drum.
