Sediment Bowl Lead Gasket
suley
First Name: Suleman
Last Name: Ishaque
* REQUIRED* Type and Year of Model Ts owned: 1925 Model T Truck
Post by suley » Tue Jan 14, 2025 4:16 pm
Hello all,
The lead gasket of the sediment bowl is out of stock everywhere for some time now. Is there an alternative to it which I can use?
TIA
Re: Sediment Bowl Lead Gasket
Post by TXGOAT2 » Tue Jan 14, 2025 4:33 pm
You might cut one from a sheet of thin lead that is made for roof flashings.
Post by Allan » Tue Jan 14, 2025 5:43 pm
Excellent advice Pat. I use a box knife for this. Be sure to make the hole first, Rough cut the OD larger than needed, fit the washer and outlet, then trim the OD in place. Otherwise it is very hard to stop things stretching to make a loose fit in the pumpkin body.
Allan from down under
suley
First Name: Suleman
Last Name: Ishaque
Post by suley » Wed Jan 15, 2025 1:34 am
Another big THANK YOU!
Shannon_in_Texas
First Name: Shannon
Last Name: Helm
Post by Shannon_in_Texas » Wed Jan 15, 2025 8:25 am
McMaster-Carr has lead sheets of various thickness available as well:
https://www.mcmaster.com/products/lead/lead~/
First Name: craig
Last Name: leach
Post by Craig Leach » Wed Jan 15, 2025 12:10 pm
In a pinch you can take Teflon tape ( a lot of it ) fold it over several times then spin it into a cord, Wrap it around many times, hold the ends
and tighten it up. Maybe we should start practicing soldering solder to make sealing rings?
Post by John kuehn » Sat Jan 18, 2025 6:58 pm
This might a good alternative for a lead gasket for the sediment bulb. I didn’t know solid lead wire is sold as fishing line! Amazon has it in a roll of 3/16”. Wrap it around the screw n connection, overlap a little. Tighten it up and cut off the overhang.
Post by Allan » Sat Jan 18, 2025 8:12 pm
John, I think that lead is used to add weight around lines without altering whatever bottom in in use. The same stuff can be used to wrap around the spokes when balancing wire wheels.
Post by TRDxB2 » Sun Jan 19, 2025 3:14 pm
who's to know its not "authentic"
