Anyone Recognize this Aftermarket Timing Cover?
Rodger Erickson
First Name: Rodger
Last Name: Erickson
Post by Rodger Erickson » Tue Feb 04, 2025 10:47 pm
Pretty sure it's not Bosch.
AndyClary
First Name: Andrew
Last Name: Clary
Re: Anyone Recognize this Aftermarket Timing Cover?
Post by AndyClary » Tue Feb 04, 2025 10:56 pm
I have one on my coupe, maybe an early Bosch plate without the thrust button? Works with the Bosch gears.
Andy
Dan McEachern
First Name: DAN
Last Name: MCEACHERN
Post by Dan McEachern » Tue Feb 04, 2025 11:12 pm
Nope- Andy gets no cigar this time.......... The plate is Atwater Kent. Gears are available from the vendors. There are two styles of AK plates in addition to the more common clip on variety. Note this one has a lower support above where the gear mounts. The other style has no lower support more like Bosch, BUT, Bosch gears will not work with either style. Center distance is totally different.
AndyClary
First Name: Andrew
Last Name: Clary
Post by AndyClary » Wed Feb 05, 2025 12:21 am
My bubble is burst. I guess that’s what happens when you assume.
Andy
DustySpokes
First Name: Edmund
Last Name: Niedzielski
* REQUIRED* Type and Year of Model Ts owned: 1914 Touring, 1922 Mercury Bodied Speedster, 1926-27 Roadsters /Tourings
Post by DustySpokes » Mon Feb 24, 2025 6:42 pm
This is identical to the Factory advertisement in the July 1921 issue of Ford Owner and Dealer, see page 26. . It is a type CA , which had automatic advance. -Dusty
