Rear fender brackets on a 26 roadster
fordt
First Name: Rob
Last Name: Trippet
* REQUIRED* Type and Year of Model Ts owned: 27 Roadster PU
Post by fordt » Mon Feb 10, 2025 6:11 pm
Should one put a washer BETWEEN the bottom (forward) hole of the rear bracket and the frame to make up for the thickness of the fender? The top (rear) hole goes thru the bracket and the fender. Or is the thickness of the fender so negligible that the bracket will just bend enough to pull it up against the frame anyway?
TMiller6
First Name: Thomas
Last Name: Miller
* REQUIRED* Type and Year of Model Ts owned: 16, 24, 26 Touring - 26 Roadster and Fordor
Board Member Since: 2006
Re: Rear fender brackets on a 26 roadster
Post by TMiller6 » Mon Feb 10, 2025 6:17 pm
I did not use washers on my rear fender brackets. Everything bolted up fine.
Tom Miller
