What's this head and value?
love2T's
Topic author - Posts: 201
- First Name: T
- Last Name: Gates
- * REQUIRED* Type and Year of Model Ts owned: 1913 Touring, 1926 Fordor
Anyone see this brand of head and got any idea what its worth? In excellent condition.
Mike Lebsack-Iowa
- First Name: Mike
- Last Name: Lebsack
- * REQUIRED* Type and Year of Model Ts owned: 11Torpedo, 11 Roadster, 13 Touring, 14 Roadster, 14 Touring
- Board Member Since: 2008
Re: What's this head and value?
That is a Giant head. Haibe and Simmons also made a head which are very very similar. All are hi compression heads. I have seen them sold in the $350-$600 range.
- Last Name: House
I have 2 GPHs on my Model Ts. Great performance enhancers. I also agree with stated price range.
Moxie26
- First Name: Robert
- Last Name: Jablonski
Got to be a little careful here... Those early high compression heads only had enough area in the head for the standard lift on the camshaft. The newer "Z" head is cast and machined to accommodate the higher lift cams to operate valves.
schwabd1
- First Name: David
- Last Name: Schwab
Hmmm..... I've got a Giant head that I was going to use with a 285 cam. Not going to work?Got to be a little careful here... Those early high compression heads only had enough area in the head for the standard lift on the camshaft.
Moxie26
Let me elaborate a little.... Standard valves with standard lift and standard diameter Will be okay to use with those early high compression heads. If you have a cam with a higher lift or a larger diameter valves, that could be a problem as those valves would hit the cylinder head... I speak from experience. The Ralph Zajac " Z " high compression head has deeper recesses for increased lift valves, but I'm not too sure about extra diameter.
Art M
- First Name: Art
- Last Name: Mirtes
David,
If you cannot use your Giant head, I could use it.
Art Mirtes
Art Mirtes
schwabd1
- First Name: David
- Last Name: Schwab
I'm going standard diameter, extra lift. I guess the only way to know is to bolt it up and check for clearance. Thanks for the heads up. Also, sorry for jumping ig on this thread, but good info for anyone with the "old" high compression heads they're thinking of using.
Les Schubert
- First Name: Les
- Last Name: Schubert
The way I check clearances for the head is set it on the block Without a gasket and use a bolt at each end for alignment. Then crank the engine slowly for at least two turns. If no contact GREAT!!
Another traditional variation is chew some gum and put some on the piston and or valves in any areas of concern and repeat the process. Inspect the gum SQUEEZING!
