Re Babbitting a fourth main
Dave1
Last Name: Eddie
* REQUIRED* Type and Year of Model Ts owned: 1926 Tudor, 1926 Touring, 1931 Plymouth PA, 1952 Hudson Hornet
Post by Dave1 » Mon Mar 17, 2025 12:19 pm
Going to re Babbitt the fourth main soon.
When it goes time to line bore to size , I will be using my lathe, which surface on the ball do I use to indicate off ?
Re: Re Babbitting a fourth main
Post by speedytinc » Mon Mar 17, 2025 12:26 pm
The machined edge under the mounting flange. This is where it contacts/centers itself in the motor.
Last Name: Hatch
Post by Dan Hatch » Mon Mar 17, 2025 1:03 pm
Find the old thread by Herm about transmission rebuilding. He shows how to .
Post by Mark Gregush » Mon Mar 17, 2025 2:58 pm
Where the flange meets the ball part, there is a machined surface, that is where you center off.
Dave1
Last Name: Eddie
Post by Dave1 » Mon Mar 17, 2025 7:13 pm
Got it thanks
Kerry
Last Name: van Ekeren
Post by Kerry » Mon Mar 17, 2025 9:24 pm
I made use of a T wheel hub flange plate as a face plate for the lathe years ago, still using it, centre the ball cap at the machined surface near the ball cap flange.
