Mystery Tool T38
namdc3
First Name: Nikolaus
Last Name: Martin
Mystery Tool T38
Post by namdc3 » Thu Mar 20, 2025 6:01 pm
Does anyone have any magical ideas on what this tool is? The only marking I can find is T 38.
Gracie'sDad
Last Name: Dow
Re: Mystery Tool T38
Post by Gracie'sDad » Thu Mar 20, 2025 6:18 pm
P 38.jpg (4.95 KiB) Viewed 2727 times
Here's a P-38.
Post by speedytinc » Thu Mar 20, 2025 6:21 pm
SWAG....Looks like it might be a front spring perch removing tool.
Only a guess.
Post by Allan » Thu Mar 20, 2025 9:13 pm
John Dow, your P38 is only half useful. Our army issue was longer and the end was dished so we could spoon the contents out of the can.
namdc3
Last Name: Martin
Post by namdc3 » Fri Mar 21, 2025 10:02 pm
I could probably open a can with it if I swung it hard enough.
First Name: Austin
Last Name: Farmer
Post by 1925 Touring » Fri Mar 21, 2025 10:15 pm
Before you do, make sure you're up on your tetanus shots... :? :roll:
Last Name: Patrick
Post by jiminbartow » Sat Mar 22, 2025 7:45 pm
Looks like some sort of bushing removal tool. After the tool is secured to the bushing housing, the center screw is tightened, pushing the bushing out.
Gracie'sDad
Last Name: Dow
Post by Gracie'sDad » Wed Mar 26, 2025 12:03 pm
Allan from Down Under,
G'dday Mate!! A spoon would be a nice feature but can you rebuild the transmission on a Deuce-and-a-Half by the side of the road with one of yours??
Post by Allan » Thu Mar 27, 2025 6:16 pm
John, if I knew what a deuce and a half was I might be able to give you an answer! Those little can openers were part of our one man army ration packs. On an exercise in North Queensland a young smart ass engineer was drafted to help in the camp kitchen for a shift, and he got on the wrong side of staff Sergeant caterer. Next thing he was given the task of opening 20 cans of baked beans for breakfast. 15 minutes later he hadn't opened a single can. The sergeant grabbed another opener and whipped the top of in a few seconds to show him how. 10 minutes later still no cans opened. He had deliberately been given an opener which had been assembled with the cutter upside down, and hadn't the nous to realise this. He was considerably less lippy after this episode.
Last Name: Patrick
Post by jiminbartow » Thu Mar 27, 2025 7:41 pm
Deuce and a half is how a 2 1/2 ton cargo truck is referred to in the military.
Gracie'sDad
Last Name: Dow
Post by Gracie'sDad » Fri Mar 28, 2025 12:35 pm
"A picture is worth a thousand words" I thought I was going to have to explain to Allan what a Deuce-and-a-half was. Thanks for the help jiminbartow!!
Last Name: Patrick
Post by jiminbartow » Fri Mar 28, 2025 1:17 pm
Glad to help John. I spent a lot of time in a deuce and a half troop transport during my 4 years as a Marine. Any military man who has ever ridden in the back of one can never forget the smell of the hot damp canvas cover. The air intake coming out of the side of the engine compartment allows the truck to ford rivers as deep as (just below) the air intake. Notice the exhaust pipe is just behind the intake and is higher than the top of the cab roof so the exhaust would not smoke out the driver and occupants. Semper Fi. Jim Patrick
Post by speedytinc » Fri Mar 28, 2025 1:58 pm
How bout the original post?
Inquiring minds want to know.
Last Name: Tannehill
Post by JTT3 » Fri Mar 28, 2025 8:50 pm
Could it be used to insert the electrodes on the sides of Frankenstein’s neck? Just spitballing here.
If it was bigger it seems it could be used to remove a crank pulley.
