Jelfified?
Topic author - Posts: 2832
- First Name: Dallas
- Last Name: Landers
Jelfified?
Fun ptoject today. I dont like to lay on the ground or burn my arm on hot exaust pipe to shut fuel off on the TT. I liked Steves idea of an external shut off so here is my version.
Its under the cab far enough to not be seen unless bending over.
Geez, I need to clean some dust off the frame!-
Re: Jelfified?
I first saw that on a TT, and liked it so much I made a version for my cars.
http://dauntlessgeezer.com/DG106.html
- First Name: Erik
- Last Name: Johnson
Re: Jelfified?
Here is an extension handle for the fuel shut-off valve on an unrestored 1925 coupe here in Minnesota - it utilizes a porcelain gas stove valve handle as shown in the photos.
- First Name: Dick
- Last Name: Fischer
Re: Jelfified?
Love the porcelain valve handle. Features like that just ooze class !
- First Name: Edward
- Last Name: Baudoux
Re: Jelfified?
I too, drew inspiration from Steve Jelf.
Grayling Michigan
1927 Fordor
1926 Huckster
1923 TT
1930 Fordor
1930 Tudor
1927 Fordor
1926 Huckster
1923 TT
1930 Fordor
1930 Tudor
- First Name: Don
- Last Name: Allen
Re: Jelfified?
So many great ideas!
I love the porcelain handle. I'll have to come up with something equally period/cool when I do mine.
1924 Touring
- First Name: Adam
- Last Name: Doleshal
Re: Jelfified?
Here is an item that I think most T owners completely overlook, and doesn’t really need an “accessory”:
If you have the regular oval or round tank, you don’t crawl under the car to shutoff the gas...
Through the passengers side door, you lift the rear of the floorboard about 1/2 way up with your left hand, reach in with your right hand, reach back under the tank, and turn the gas off or on. Try it...
- First Name: Brent
- Last Name: Burger
- Board Member Since: 2014
Re: Jelfified?
But the "Farmer Brown" accessory (junk pile retrieved) handle MAKES the vehicle
that much better. I have a box of nice purple door knobs that might look good. The
shop is full of treasures like this, just looking for a great use again ! Great idea, Dallas.
Even better with the cool old repurposed handle. Really catches the period "attitude".
- Last Name: Hanlon
Re: Jelfified?
I do what Adam does. As Dallas says, you gotta watch the exhaust pipe !!
Best to wait a while for cool down...
- Last Name: Stroud
- Board Member Since: 2011
Re: Jelfified?
But Adam, you don't have to lift anything or be a contortionest to just turn that nice little handle on the outside. I have arthritic spurs in my lower spine, bending over to do anything can be a struggle. I have a couple of cutoff spark and throttle ears that will make a nice handle. If someone wants one of them, you can have it for shipping. Dave
1925 mostly original coupe.
- Last Name: Warren
Re: Jelfified?
I was recently Jelfified. On my way to Lincoln Nebraska to to the speedster reunion I stopped and met the man, the myth, the legend
. It was great finally meeting Steve and sharing some stories. He has paintable place Rich. [attachment=0]
- Last Name: Warren
Re: Jelfified?
- First Name: George P
- Last Name: Clipner
Re: Jelfified?
The man
the myth
The bad influence
His old farm house is amazing, built from river rocks fun of some of the most amazing fossils
the myth
The bad influence
- Last Name: Warren
Re: Jelfified?
All I could say was WOW
