The Turbo400 Inner Clutch Disk
J1MGOLDEN
Last Name: Golden
Post by J1MGOLDEN » Thu Apr 10, 2025 9:13 am
Is the Turbo400 Inner Clutch Disk a thing of the past or is someone still making them?
I am having a problem finding one.
Re: The Turbo400 Inner Clutch Disk
Post by speedytinc » Thu Apr 10, 2025 10:26 am
Chaffins still sells the heavy duty disk set.
J1MGOLDEN
Last Name: Golden
Post by J1MGOLDEN » Thu Apr 10, 2025 10:37 am
Chaffins does not have Part Number 3332 modified with many small grooves to accept the Turbo400 Disks with all the notches listed in their on-line catalog!
That is the part number I need and can't find.
I will call Dave a little later, after he gets to work.
They do have the equipment to make that part!
Post by speedytinc » Thu Apr 10, 2025 11:12 am
Who convinced you a special hub is needed?
Modified disks function the same.
I have well over 10K miles on a set. During the last motor refresh I inspected & found such minimal wear on the teeth & lining material, I reused them.
I run them in all my T's. All have higher horsepower motors. One is a BB Rajo motor.
Not trying to start a debate. I just don't swallow the BS that floats around out there.
Good luck with your search.
tman1913
Last Name: Bender
* REQUIRED* Type and Year of Model Ts owned: 1913 Canadian touring, 1924 Roadster, 1926 Mercury speedster, 1927 Roadster p/u, 1920’s bobtail dirt track racer
Post by tman1913 » Thu Apr 10, 2025 11:38 am
Check with Langs. They had them at one time.
J1MGOLDEN
Last Name: Golden
Post by J1MGOLDEN » Thu Apr 10, 2025 1:00 pm
The problem I have is the center modified gear is on the shaft so tight that it is warped now and still will not come off the transmission shaft.
Dave said they can be straightened with a press.
That will only work if they can be separated in one piece.
That wheel was sold as a Jackrabbit Low Speed Clutch Set or Kit.
It was never sold separately!
None of those have been manufactured for several years now, which suggests Henry Ford was correct the way he had them made and no replacement was required.
J1MGOLDEN
Last Name: Golden
Post by J1MGOLDEN » Thu Apr 10, 2025 1:03 pm
Langs does not have any now!
Don was checked first, as that is where this one came from several years ago.
Post by Mark Gregush » Thu Apr 10, 2025 2:22 pm
Page 19 of the clubs Transmission book shows how to make your own that would work with the original clutch drum.
ModelTWoods
First Name: Terry
Last Name: Woods
Post by ModelTWoods » Thu Apr 10, 2025 3:49 pm
Expecting to do a transmission refresh, soon, I wanted to replace the original discs to get a "free" neutral, which I've never had. I decided on either Turbo 400 or a Jack Rabbit disk set. I checked Lang's online catalog and did not see the hub and disc set, so I sent them a message through their website. They responded that the individual who made the hub had a broken CNC machine used to make them and had promised to make them as soon as the machine was repaired. They said that they have been waiting a YEAR and still have not heard anything from him.
Erik Barrett
First Name: Erik
Last Name: Barrett
Post by Erik Barrett » Thu Apr 10, 2025 10:49 pm
Anyone considering using the turbo clutch be advised these plates were designed to be applied by hydraulic pressure, not a coil spring. As such always use a new spring. They have a little more tension than the originals and that is crucial to successful use of the turbo clutch.
Post by DanTreace » Fri Apr 11, 2025 6:30 am
The Jack Rabbit style sold by Synders is IMO the way to go, works in my T’s.
The Turbo drum with the special multi grooves for the turbo discs isn’t made.
Plus in one install the special drum fractured trying to pull it off.
That drum is Cast Steel or some alloy,unlike forged Ford drum. It stuck on the shaft and puller broke away the removal hole on one side. Very little wall thickness at the removal holes, poor design. Had to drill and cut the cast thing off. :x (Posted that on Oct 30 2022)
Jack Rabbit style uses the factory forged drum.
J1MGOLDEN
Last Name: Golden
Post by J1MGOLDEN » Fri Apr 11, 2025 9:57 am
Dan, thanks for the photos.
Now, I only have to find one that is for sale!
There are plenty of the related disk packs anyway.
First Name: craig
Last Name: leach
Post by Craig Leach » Fri Apr 18, 2025 1:49 pm
I see from the pic that the material used on the Jackrabbit clutch has changed to the same as the Turbo 400? That may make some more
comfortable with them. I have years on the cut down Turbo 400s with no issue I even put them back in after breaking a low drum.
greenacres36
First Name: Brian
Last Name: Williams
* REQUIRED* Type and Year of Model Ts owned: 1926 Tudor, 1915 Runabout
Post by greenacres36 » Fri Apr 18, 2025 2:44 pm
At one time I considered making some TH 400 drums to sell. I just didn’t think that there was any demand. Besides a new jackrabbit clutch would probably be cheaper and probably last longer
First Name: craig
Last Name: leach
Post by Craig Leach » Fri Apr 25, 2025 7:19 pm
I picked up a home made Turbo 400 hub years ago still haven't used it yet
J1MGOLDEN
Last Name: Golden
Post by J1MGOLDEN » Sat Apr 26, 2025 5:05 pm
The Jackrabbit Clutch disk pack was the secret, as it comes with 8 thicker Turbo400 disks and only uses 9 original disks with it, or perhaps 10 and they are available.
The main advantage is it improves the ability to shift from Lo to Hi or Hi to Low.
Snyders had a set and the transmission is back together now.
