TRADE ONLY flip style Fatman wheel
Karl Von Neumann
First Name: Karl
Last Name: VonNeumann
Board Member Since: 2022
Post by Karl Von Neumann » Mon Apr 14, 2025 2:06 pm
I have this flip style Fatman steering wheel I'm looking to trade for a slide style wheel I will not sell mine unless you give me stupid money 😜
Re: TRADE ONLY flip style Fatman wheel
Post by RajoRacer » Mon Apr 14, 2025 3:56 pm
That's a Bauer - you're referring to a Neville - good luck on that !!!
South Park Zephyr
Last Name: Francis
Post by South Park Zephyr » Tue Apr 15, 2025 7:12 am
There is one on eBay with about 3 1/2 days left
https://www.ebay.com/itm/256890405851
Post by TRDxB2 » Tue Apr 15, 2025 9:45 am
That will not fit a Model T. For aModel T it needs a hum that goes over the steering cap will add photo later
Post by RajoRacer » Tue Apr 15, 2025 10:55 am
The correct Neville "Slider" for a Model T has the same profile as a stock wheel - the rim is below the spyder. The one Frank listed could possibly be used if the mounting hole is 3/4" - I've seen that type on a Model T but they look peculiar !
Post by TRDxB2 » Tue Apr 15, 2025 11:44 am
These re the two types that I am aware of made for a Model T.
One is for easy access to throttle & advance levers
neville 2.jpg (80.48 KiB) Viewed 1648 times
Karl Von Neumann
First Name: Karl
Post by Karl Von Neumann » Tue Apr 15, 2025 11:10 pm
For reference I'm running a dodge column in my couoe takes the same shaft size as the T so I could care less either way 😅
