I have a 1922 Touring Car and need some parts for the battery area.
Wood Box
Metal Box
Correct Lid
Is Larry Smith still around and how do you buy a metal battery Box from him?
Metal Battery Box and Wood Battery Box
- Last Name: Strange
Re: Metal Battery Box and Wood Battery Box
Yes, Larry Smith is still around, you can contact him via PM to "original_smith" on this site. I don't know if he is currently offering metal battery boxes. You would still have to find an original lid, they aren't reproduced by anyone that I know of.
Here is an older post regarding battery boxes, including dimensions if you want to try and make your own: https://mtfca.com/phpBB3/viewtopic.php?t=24099
- First Name: Gary
- Last Name: Hagen
I could use some clips
Adam, you need a metal battery box and the lid with the rounded edges to suit your 22 model. The wooden battery "box' was actually the battery case into which the plates and acid were fitted. Today the battery case is plastic. Between the wooden case and today's plastic ones, the cases were made of hard rubber.
I'm not having the metal lower battery boxes made any more. They were exact copies of the originals. The current offerings are not 100% correct, and will not work with an original top.
Topic author - Posts: 5
- First Name: Adam
- Last Name: Corts
- * REQUIRED* Type and Year of Model Ts owned: Touring 1922
Dang! Im always late to the party. Do you have a line on one or know anyone that might have one?
