Looking to change the oil in the Warford transmission. This is an older aluminum unit. Does anyone know the capacity so I know how much to order?
Older aluminum Warford oil capacity
Re: Older aluminum Warford oil capacity
Here is older forum post on quantity:
By Mark Gregush Portland Oregon on Sunday, August 06, 2017 - 06:47 pm:
Warford original 2 or 3 speed aluminum case, in ether case would be up to bottom of fill opening.
My original cast iron 3 speed took between 2 and 3+ pints as I recall, I just put in till got to level I suggested above.
- First Name: Adam
- Last Name: Doleshal
You don’t have to order oil. It’s 85w140 and every place has it.
Do some research on what to use. I restored one & used 600 wt model a lube. Ran quiet & shifted well.
Topic author - Posts: 112
- First Name: Jim
- Last Name: Sarc
- * REQUIRED* Type and Year of Model Ts owned: 1926 Roadster Pickup
- Board Member Since: 2023
Thanks Dan. I found that post also when using search function but it didn’t state quantity for the aluminum case. I assume it’s similar and get a quart.
DanTreace wrote: ↑Sun Apr 27, 2025 6:29 pmHere is older forum post on quantity:
- First Name: Jim
- Last Name: Sarc
Thanks. That’s what I was thinking of using from using the search function.
speedytinc wrote: ↑Sun Apr 27, 2025 9:11 pmDo some research on what to use. I restored one & used 600 wt model a lube. Ran quiet & shifted well.
