MYSTERY PART
Mark Chaffin
Topic author - Posts: 4400
- Last Name: Chaffin
MYSTERY PART
Found these at a recent estate sale. Not likely T. Similar to Model A front axle spring perch. I'm calling on the antique car gurus to possibly identify the application.
Dan McEachern
- First Name: DAN
- Last Name: MCEACHERN
Re: MYSTERY PART
Aftermarket hot rod front spring perches.
Mark Chaffin
Re: MYSTERY PART
I thought so as well; however, they appear old and threads are dipped in wax.
Mark Chaffin
Re: MYSTERY PART
You may be right Dan.
Re: MYSTERY PART
Good for Bucket T
Re: MYSTERY PART
The dippped threads are typical of military spec preservaton of spares. That also would indicate an older manufacture.
pete eastwood
- First Name: Pete
- Last Name: Eastwood
Re: MYSTERY PART
Those are "PSI" brand spring perches.
PSI was in business in the 60's & 70's & 80's making hot rod stuff.
They were in Rosemead Calif.
Mark Chaffin
Re: MYSTERY PART
Thank you Dan and Pete. Makes perfect sense to me.
tdump
- First Name: Mack
- Last Name: Cole
Re: MYSTERY PART
i wonder if they would work in a stock T axle?? that would lower the car a bit
- First Name: Henry
- Last Name: Lee
Re: MYSTERY PART
Those were made for split adjustable hair pin radius rods…, so you could dial in the caster!
Hank
Hank
CamMan
- Last Name: Young
- * REQUIRED* Type and Year of Model Ts owned: '26 Tudor, '22 speedster, ABC/Rajo
Re: MYSTERY PART
I haven't seen that idea before, but it should allow lowering the car by dearching of the spring. If you did that with a standard perch the suspension geometry would screwed up.
