A Facebook Marketplace Treasure...
Post by Jerry VanOoteghem » Tue Jun 03, 2025 4:19 pm
I was scanning through FB Marketplace the other day, just looking at machinery for sale, when an ad caught my eye. I wasn't even thinking about T stuff when this popped up. I thought it might be a scam, but for the $70 asking price I thought I'd give it a shot. It arrived today...
Last edited by Jerry VanOoteghem on Tue Jun 03, 2025 4:20 pm, edited 1 time in total.
Re: A Facebook Marketplace Treasure...
Post by Jerry VanOoteghem » Tue Jun 03, 2025 4:20 pm
Post by speedytinc » Tue Jun 03, 2025 4:34 pm
SCORE!!!!!!!!!!!!
Post by DanTreace » Tue Jun 03, 2025 5:26 pm
Great find! Congrats.
Now get Dan Hatch’s taper reamer to complete that set!
Post by Jerry VanOoteghem » Tue Jun 03, 2025 5:47 pm
Yup, I thought of that Dan. I believe he only sells the tap & reamer as a set, however.
Post by John kuehn » Tue Jun 03, 2025 6:02 pm
That’s super neat to find the box with it! It doesn’t look beat up either. Really good things are out there and you have to be at the right place at the right time!
Last Name: Juhl
Post by Oldav8tor » Tue Jun 03, 2025 8:16 pm
Score one for Jerry! What a find!
dobro1956
First Name: Donnie
Last Name: Brown
Post by dobro1956 » Tue Jun 03, 2025 8:35 pm
Great score. Even if you buy the pair of reamers from Dan, you are still doing very good as to price. I would recommend to get the reamers from Dan and also look for a single taper reamer to complete your set. Having a extra pair of reamers is a wise investment. Dan has almost quit making them a couple times. He may not have them for sale much longer. Make sure to use the thrust washer on the reamers while using it. The reamers will cut backwards into the fixture with out the thrust washer, ruining the fixture.,
Post by Jerry VanOoteghem » Tue Jun 03, 2025 8:44 pm
Great score. Even if you buy the pair of reamers from Dan, you are still doing very good as to price. I would recommend to get the reamers from Dan and also look for a single taper reamer to complete your set. Having a extra pair of reamers is a wise investment. Dan has almost quit making them a couple times. He may not have them for sale much longer. Make sure to get a thrust washer to use on the reamers while using it. The reamers will cut backwards into the fixture with out the thrust washer, ruining the fixture.,
I believe the thrust washers are there, but I had no idea what they were for... until now. Thanks!
Post by Jerry VanOoteghem » Tue Jun 03, 2025 8:46 pm
Thanks guys! This has been a fun little find. :)
dobro1956
First Name: Donnie
Last Name: Brown
Post by dobro1956 » Tue Jun 03, 2025 8:55 pm
I did not notice the washers were there till I looked at the photos again. Yes the thrust washers are there. I changed my post, but not before you commented. This is a very useful tool. One other thing to remember is to check the front axle with a file before using the taps. If the axle has become "work hardened" from use, the reamers can be ruined by using them on the hardened axle. To check, take a file and file all 4 of the wear surfaces on the axle. If a file does not "cut" , then the axle needs "annealed". To anneal the axle, shine up all four of the wear surfaces with sandpaper or stone. Just enough to be "shiney". Then heat each area slowly with a torch till the shiney surface is just starting to turn "blue". Then let cool off slowly. They will then be "annealed" and safe to use the reamers on. Use lots of oil or tap fluid and clean often as reaming.
Last Name: Hatch
Post by Dan Hatch » Tue Jun 03, 2025 9:40 pm
Jerry: nice score. Email me by forum. Dan
Post by Allan » Wed Jun 04, 2025 4:15 am
That's a find almost worth joining the Facebook farce.
Ed Baudoux
First Name: Edward
Last Name: Baudoux
Post by Ed Baudoux » Wed Jun 04, 2025 8:44 am
Jerry Van:
"I wasn't even thinking about T stuff". Fake News! 🤣
Grayling Michigan
1927 Fordor
1926 Huckster
1923 TT
1930 Fordor
1930 Tudor
love2T's
First Name: T
Last Name: Gates
Post by love2T's » Wed Jun 04, 2025 9:29 am
WOW! someone sure didn't know what they had!! :lol:
There is this command as I recall.... "thou shall not steal"! :lol: :lol: Oh, you did pay for it! :lol: :lol: Absolved.
Post by Jerry VanOoteghem » Wed Jun 04, 2025 11:49 am
Jerry Van:
You caught me :?
Post by Jerry VanOoteghem » Wed Jun 04, 2025 11:54 am
Actually, he did know what it was, since it included an original sales ad.
TMiller6
First Name: Thomas
Last Name: Miller
* REQUIRED* Type and Year of Model Ts owned: 16, 24, 26 Touring - 26 Roadster and Fordor
Board Member Since: 2006
Post by TMiller6 » Wed Jun 04, 2025 8:08 pm
Well done Jerry!
Tom Miller
