Wire wheels identification needed
Topic author - Posts: 481
- First Name: Philip
- Last Name: Lawrence
- * REQUIRED* Type and Year of Model Ts owned: 1914 Touring, 1917 Runabout, 1919 Touring
- Board Member Since: 2014
I would like help in identifying this wire wheel. If possible, could someone please post photos of the correct hub and hub cap to fit this wheel? Thanks in advance.
- First Name: Kevin
- Last Name: Pharis
Re: Wire wheels identification needed
Looks very similar to a “Universal” wire wheel, which is the inspiration behind the currently produced McLaren wire wheels. The wheel should bolt directly to a stock wood wheel hub, and the cap is simply a dust shield. Of course, there is always the chance that this wheel could have nothing to do a Ford, and fit one of the dozens of other makes from the T era.
The lacing pattern is light duty, and the spoke count appears to be low (approximately 44). Definitely for a very light weight and low power car
Post from 2021 showing Universal wheels, scroll to bottom of the thread.
https://share.google/GxJHq4H7plEnAOvx1
