Edit: after correcting my error, I don't need another drag link spring cap.
I can't seem to find the drag link cap, it's discontinued where ever I see it posted, but I don't mind used. The horn I'm looking for is the side mounted klaxon hand horn the aoogah one with the rod you press down or forward to make it sound. And lastly, the apco spring cap for the wishbone, I too can't find. The only thing I've seen were some expensive klaxons on eBay which I can't afford. If anyone is letting go a horn reasonably cheap let me know, and same for the other parts. Thank you.
Looking for apco spring wishbone cap and a hand horn
Topic author - Posts: 109
- First Name: Lucas
- Last Name: Milatti
- * REQUIRED* Type and Year of Model Ts owned: 1917 Model T Touring
- Board Member Since: 2025
Last edited by LittleTimmy52 on Sun Jun 29, 2025 11:50 am, edited 1 time in total.
Re: Looking for apco spring drag link cap, and wishbone cap and a hand horn
I have some used ones, with some wear.
Try Langs
Wishbone https://www.modeltford.com/item/2736ST.aspx
Drag link https://www.modeltford.com/item/2728ST.aspx
Try Langs
- First Name: Don
- Last Name: Lang
- * REQUIRED* Type and Year of Model Ts owned: Multiple years
Re: Looking for apco spring wishbone cap and a hand horn
We have some available
1-800-872-7871
Lang’s
1-800-872-7871
Lang’s
