There is a pickup listed for sale and it says new U channel. Is that the piece that goes down either side of the frame from behind the bottom of the seatbacķ on a roadster to the rear of the body and connects to the floor under the turtle on a 26?
If that is it, are they available or do you manufacture your own?
That piece on my 26 pickup is rusted out for several inches behind the bucket.
What is a U channei
Dennis_Brown
Topic author - Posts: 261
- First Name: Dennis
- Last Name: Brown
- * REQUIRED* Type and Year of Model Ts owned: 1926 Roadster pickup
- Last Name: Patrick
Re: What is a U channei
Steel descriptions are basically the cross section shape of the steel being described. An i - beam has the cross section of a capital i or an H. Angle iron has the 90 degree cross section of an L. Flat bar is flat. Square bar is a square bar. Round bar is a round bar. U-channel has the cross section of a square U. The long sides of the Model T chassis is made of U channel. These shapes can be purchased in a wide variety of sizes. Sold by the lb.
Dennis
Lang’s has that pickup bed part.
Dodge
- First Name: Dodge
- Last Name: Riedy
- * REQUIRED* Type and Year of Model Ts owned: 1915 Ford Center Door
Nota my Channel, musta be a youa Channel.
