922-1927 Drive Shaft Assembly Revision E
VowellArt
First Name: Martynn
Last Name: Vowell
Board Member Since: 2012
Post by VowellArt » Tue Jul 15, 2025 10:45 pm
Whilst rebuilding my rear axle and driveshaft, I came across an error in the drawing I made of the 22-27 driveshaft. The parts 2596, 2591 and 2591B were in the wrong alignment.
Also added the Spool Cap Screws 2584B and the rear axle "Pumpkin" for reference.
Fun never quits!
First Name: Adrian
Last Name: Whiteman
Re: 922-1927 Drive Shaft Assembly Revision E
Post by A Whiteman » Wed Jul 16, 2025 12:19 am
Thanks for the fix Martynn, these are very helpful,
cheers
Adrian
Post by DanTreace » Wed Jul 16, 2025 8:27 am
Very nice.
Just one more minor addition, a note may be helpful to “Drill grease hole halfway thru bushing 2581 in-line with 2545 grease cup.”
Those bushings come un-drilled and grease can’t get to the inner surfaces to the drive shaft without such a hole. Should be about 1/4” dia. hole.
Post by Jerry VanOoteghem » Wed Jul 16, 2025 9:11 am
There should be a notch in 2596, shown in the 12 o'clock position, adjacent to the pinion gear, which will align with the woodruff key 2598B. I maybe see the hint of such a notch in your drawing, but if so, it's not oriented to align with the woodruff key.
You do fantastic work!!!
VowellArt
First Name: Martynn
Last Name: Vowell
Post by VowellArt » Thu Jul 17, 2025 4:30 am
Not sure of the wording, but I do have a color cross section of this assembly that shows the placement of this hole quite clearly and its alignment with Grease/Dope Cup 2545.
Fun never quits!
