Forum failure this AM - we caught it.
Can’t log in? Having a problem with the Forums? Have a question about how something works? Get support here.
AdminJeff
Post by AdminJeff » Fri Jan 18, 2019 11:11 am
We know the site went down this AM. I was actually monitoring it when it went down so I have lots of data for the ultra-techie Linux support geeks to pour over. We're trying to track down the root cause. It's a thorny issue. Rest assured both ChrisB and I are all over this.
Sorry for the delay in getting it back online this AM. Sometimes you need to keep the system in a failed state so you can do forensic analysis and figure out why its happening. I can assure everyone we'll only do that when absolutely necessary and get it back online ASAP. I personally know how addicting these forums are at 3AM!!
I'm going to take one for the team here. if you notice the site go down, send me a TXT "MTFCA SITE DOWN" to Seven 0 Seven - 532-5773
Please only send me a txt only if you get this parrticular error when trying to access the site:
pls don't do it at 3am... if that happens, email jeff at vinopro dot com or ChrisB.
For other support issues, we'll use the (working) forums for that.
Jeff
RustyFords
First Name: Don
Last Name: Allen
Re: Forum failure this AM - we caught it.
Post by RustyFords » Fri Jan 18, 2019 11:22 am
My phpBB board crashes about twice a year.
It's fairly easy to fix
1924 Touring
Post by Mark Gregush » Fri Jan 18, 2019 11:26 am
The same day that the private messages was taken off I received the same notice when I tried to sign in.
Novice
First Name: Jim
Last Name: Davis
Post by Novice » Fri Jan 18, 2019 11:29 am
THANKS. FYI the forum was also down yesterday 12-17-2019 for a while. I figured You guys were working on it. So I did not report or post outage it came back up after a while.
DLodge
First Name: Dick
Last Name: Lodge
Post by DLodge » Fri Jan 18, 2019 12:01 pm
Thanks, Jeff. I have added your phone to my contact list in the fervent hope that I will never have to use it. :D
AdminJeff
Post by AdminJeff » Fri Jan 18, 2019 12:17 pm
Yes, its easy to fix - restart the server. The question is WHY? what is causing it? babysitting forums that thousands of folks use for crashes isn't fun... so we're on a search and destroy mission and we won't stop until we nail it.
Jeff
RustyFords
First Name: Don
Last Name: Allen
Post by RustyFords » Fri Jan 18, 2019 12:34 pm
Jeff
I'm not running my own server. If yall are...then bless you. And may the force be with you.
1924 Touring
Tiger Tim
Last Name: Eckensviller
* REQUIRED* Type and Year of Model Ts owned: 1926 cut-off touring
Post by Tiger Tim » Fri Jan 18, 2019 12:41 pm
Did someone install a filter on the forum when it was being set up? The internet is electrical but it seems 99% of electrical problems are actually fuel, after all...
AdminJeff
Post by AdminJeff » Fri Jan 18, 2019 3:35 pm
The only filter we considered installing was the "Check if user is a little wacko before allowing posts" Filter. We opted to not install that filter since I wouldn't be able to post and help you guys. :shock:
Jeff
Ruxstel24
Last Name: Hanlon
Post by Ruxstel24 » Fri Jan 18, 2019 3:56 pm
Jeff
I resemble that remark !! :lol:
