1913 Speedster, a 3-Generation Build
AEyssen
Topic author - Posts: 45
- First Name: Alex
- Last Name: Eyssen
Starting a build thread to track the progress of a “new” speedster build by an enthusiastic 16 y/o, his dad who will document the process (me), and his Model T part supplier & MTFCA past prez grandfather (@tmdltim).
First step was a trip to Texas and home of Cast Iron Automotive where 95% of the parts were pulled off dusty shelves and laid out on the shop floor.
The heart of the car is a restored & running 1913 engine from the late Prestley Morris. Already 060 over, it will get a high compression aluminum head and specialty carb.
1915 Model T Touring
- Last Name: Tannehill
Re: 1913 Speedster, a 3-Generation Build
Congrats this is going to be fun! Thanks for letting us follow your progress. Best John
AEyssen
- First Name: Alex
- Last Name: Eyssen
Step 2 was driving all the parts & pieces 19 hours to North Carolina. There, the parts will get the usual prep, paint, and assembly.
But not before the method of dropping the frame a few inches is determined and fabricated.
AEyssen
- First Name: Alex
- Last Name: Eyssen
Parts arrived home and work is ongoing (at least until school starts in 3 weeks). Follow along here or on Instagram @diyluke
tdump
- First Name: Mack
- Last Name: Cole
Glad to see the younger 1's taking a liking to the T's!
TeveS-Nor Cal
- Last Name: Straw
- * REQUIRED* Type and Year of Model Ts owned: 1915 and lots of parts
Going to be a fun series of posts. Keep em coming!
Chris Instness
- First Name: Christopher
- Last Name: Instness
- * REQUIRED* Type and Year of Model Ts owned: 1915 runabout, T speedster
Looking forward to seeing the progress!
AEyssen
- First Name: Alex
- Last Name: Eyssen
Rough mock up continues. Aux transmission will get a custom bracket and married to an already shortened drive shaft. Lowering steering column angle next priority.
AEyssen
- First Name: Alex
- Last Name: Eyssen
Front spindles coming together. Sanded, primed, painted, clear coated, and new bushings installed.
- Last Name: Hjortnaes
Remind him that he will be most comfortable if he tilts the seats back about 10-15 degrees. Wish I had done it with my speedster.
Thank you for the post. I will enjoy reading it.
Laying the seat back helps, but it still needs to be positioned correctly for the individual driver's comfort. If it is a bucket seat installed individually on the body base, you could consider more than one set of mounting points so it can be shifted at will.
Powerwagonmaniac1
- First Name: Chris
- Last Name: Becker
- * REQUIRED* Type and Year of Model Ts owned: 1919 touring, 1917 speedster, 1925 give or take roadster pickup
Glad to see the next generations build. Carston are having so much with "Nuthin' Special" his little ' 23 rpu. Check out his build thread under Nuthin Special for some inspiration. Dad and Grandpa good on you guys passing it on!
AEyssen
- First Name: Alex
- Last Name: Eyssen
Great looking build. Will check out your thread!
AEyssen
- First Name: Alex
- Last Name: Eyssen
More gears! The speedster will have a Muncie aux transmission. Luke cut, welded, and painted a support bracket.
Mark Nunn
- Last Name: Nunn
The spindle arm nut should not be tightened onto the spindle until after the front suspension is assembled. The tie rod's bolts will dictate the position of the arm on spindles. Tightening before final assembly will guarantee binding.
Luke & Alex if you have not planned to put auxiliary brakes on your speedster, I strongly recommend you do so since you are putting in an auxiliary transmission. Using period auxiliary transmissions or rear axles make it imperative to do so. If they jump out of gear or your locked out from shifting into a gear puts you in a bad situation with no real way to stop. I’m enjoying the build & progress keep up the good work.
Best John
Best John
- First Name: craig
- Last Name: leach
Great to see the younger generations get into the hobby. I built a 1966 Chevy pickup with my granddaughter best time ever!!! Muncie as a great
choice, with reverse you can eliminate the low peddle & lower the steering column even more. I hate to be a stick in the mud but I would figure
out a trans mount the will allow the frame to flex more than that one will, There should be a drilled & taped hole on the underside of the Muncie
tail shaft that will work very well. Model T frames flex a lot I find it best to not try to stop them from flexing.
AEyssen
- First Name: Alex
- Last Name: Eyssen
Great advice. Yes we heard that there is risk of moving and unable to get back into a gear. We have a set of new Rocky Mountain brakes that will get painted and installed.JTT3 wrote: ↑Tue Aug 13, 2024 7:56 pmLuke & Alex if you have not planned to put auxiliary brakes on your speedster, I strongly recommend you do so since you are putting in an auxiliary transmission. Using period auxiliary transmissions or rear axles make it imperative to do so. If they jump out of gear or your locked out from shifting into a gear puts you in a bad situation with no real way to stop. I’m enjoying the build & progress keep up the good work.
Best John
AEyssen
- First Name: Alex
- Last Name: Eyssen
The engine - a ‘13 - will get an aluminum head upgrade. Machine shop cleaned it up before install. New copper head gasket ready too.
Fantastic stuff!
Thank you for taking us along.
AEyssen
- First Name: Alex
- Last Name: Eyssen
The speedster will get a set of wires to accompany its later model running axles. We are ready to make it a roller. But before mounting the new tires, we need to pick a wheel color. Unfortunately these two shades of green aren’t it (left side vs right side).
Either of this two shades of green would go well with a vivid yellow body colour.
AEyssen
- First Name: Alex
- Last Name: Eyssen
Driveline assembled tonight. Luke got the shortened drive shaft bolted up to the Muncie and the rear end. Added new 600W in the process. Fun to see the axles spin with the turn of the hand crank.
AEyssen
- First Name: Alex
- Last Name: Eyssen
The biggest new purchase so far is the birch firewall. Stain and polyurethane added before it gets bolted up to the chassis this weekend.
AEyssen
- First Name: Alex
- Last Name: Eyssen
First wheel mounted. Decided on black color. Three more to go then we will have a roller.
Alot easier to mount tires on wire wheels whilst on the car !
Fitting tyres that way gives valuable experience. Now he knows how to do it, he is well set.
The even easier way is to have a tyre shop do it. My fellow puts a little electrical tape on the four "grippers" to protect the paintwork. The mounting head goes around the wheel 1/8" above the outer edge of the rim, so no paint damage there either. 10 minutes per wheel, done and dusted!
Except for a couple modern cars with weird modern shallow rims very hard to do without a big expensive machine? All my life I have done nearly all my tire work myself both antique and modern. People often ask me why? I tell them that usually, I can do the entire repair myself with my basic tools in less time than it takes to drive them to the tire shop and wait to fill out the repair forms and drive home, then return later to pick them up.
Always wise to not be too dependent upon others anyway!
I do a lot of our local clubs' tire mounting - the knees don't appreciate the floor much anymore so I purchased this manual machine for motorcycle tires - works on wires, clinchers & split rims.
AEyssen
- First Name: Alex
- Last Name: Eyssen
John Codman
- Last Name: Codman
Love the speedster - the Stearman 75 ain't exactly chopped liver either!
AEyssen
- First Name: Alex
- Last Name: Eyssen
It’s finally a roller. Major components installed. Still planning to “z” the rear frame to align with the drop axle.
AEyssen
- First Name: Alex
- Last Name: Eyssen
Progress continues. The firewall has since been lowered and moved back and steering column lowered.
AEyssen
- First Name: Alex
- Last Name: Eyssen
Maiden voyage of around 15 miles. Stopped by our local hardware shop where lots of the small hardware pieces were sourced. Then lunch. Ran great.
- First Name: Adrian
- Last Name: Whiteman
This is great to see! Enjoy!
Thanks for sharing the journey.
Can I suggest this method for cotter pin install:
Or the US Military way:
AEyssen
- First Name: Alex
- Last Name: Eyssen
The summer goal for Luke was to build and drive the speedster to his high school auto club car show this Fall. It’s got about 100 miles on it so far.
AEyssen
- First Name: Alex
- Last Name: Eyssen
Luke has lots of plans in 2025 for the speedster. One included testing out a “speederator”.
Chris Paulsen
- First Name: Chris
- Last Name: Paulsen
- * REQUIRED* Type and Year of Model Ts owned: 1910 Touring, 1914 Pickup
I like that speederator - it seems so simple. Does it attach to the hand throttle too? Or just foot throttle?
Great to meet you both a couple weeks ago!
AEyssen
- First Name: Alex
- Last Name: Eyssen
Yes it does connect to the throttle too. It has a slide feature so you can drive with either the peddle or stock throttle (ignore the stacked nuts for spacing
). It also came with tabs that once mounted touch to other peddles and act to disengage foot throttle if you press the other peddles. Luke hasn’t installed those yet. First drive tonight and he said it worked fine.
AEyssen
- First Name: Alex
- Last Name: Eyssen
Oh and yes great to meet too. We are returning in May for the CARS events. Looking forward to it and saying hello again.
AEyssen
- First Name: Alex
- Last Name: Eyssen
The speedster has been racking up miles. While interning at a Ford dealership, Luke took the car for show & tell.
AEyssen
- First Name: Alex
- Last Name: Eyssen
Luke swapped out the Holly carb for this unique Rayfield (Pat. 1911) and intake manifold. We don’t know much about it. The needle tip needed repaired. Lots of adjustment options but it’s running and driving well with it.
AEyssen
- First Name: Alex
- Last Name: Eyssen
The speedster has been accepted to The Race of the Gentlemen 2025. The race requires a roll bar so Luke, with the help of a great teacher, was able to make a custom roll bar (75% so far) that will be mounted to the frame rails. It will have a couple gussets & braces, then will be fully tig welded.
AEyssen
- First Name: Alex
- Last Name: Eyssen
One month until TROG. At the Winter Clinic, Luke was inspired by the Ford special racer and its headers. So, he designed a manifold plate on the computer, 3D printed it in plastic to confirm fitment, then sent the file to SendCutSend. He TIG welded it (another first) with the help of a mentor. The finished, heat coated headers look and sound great (and spits the occasional flame).
AEyssen
- First Name: Alex
- Last Name: Eyssen
Past couple months the speedster has made several appearances- Prism Motorcycle show, Cars & Coffee meet ups, and a Great Race overnight stop where Luke met longtime Great Racer Curtis Graf.
AEyssen
- First Name: Alex
- Last Name: Eyssen
Luke decided to make a half hood. Kinda difficult with only a grinder and without an English wheel. But, it is taking shape. Not sure why the pics are rotated.
- Attachments
- IMG_0983-compressed.jpeg (95.31 KiB) Viewed 1987 times
- IMG_0980-compressed.jpeg (99.34 KiB) Viewed 1987 times
- IMG_0967-compressed.jpeg (73.12 KiB) Viewed 1987 times
AEyssen
- First Name: Alex
- Last Name: Eyssen
One of the many highlights of this build has been the many mentors who have offered Luke advice, parts, time and tricks of the trade. The speedster needed a seat cushion for the metal bomber seat. So Luke sought out help from an upholstery guru, who helped and taught him how to make a padded, vintage looking seat cushion.
AEyssen
- First Name: Alex
- Last Name: Eyssen
Just a couple weeks before two major T events and Luke started feeling a little clutch slippage. So, he single-handedly pulled the engine, dropped the pan, and removed the hogs head. Pulled the fiber Watts clutch out and installed a metal clutch pack and new, stronger spring. Process required he make a clutch spring tool.
AEyssen
- First Name: Alex
- Last Name: Eyssen
Only 1 week before The Race of Gentlemen and two weeks before the Texas T Party. So, crunch time for all the final preps.
Besides the tension of the straps, I'm hoping there is something on the bottom side of the hood to prevent it from sliding backwards, towards the driver.
Very cool BTW. I'm already jealous of the fun you'll have in the race!
AEyssen
- First Name: Alex
- Last Name: Eyssen
Yes, great question. Luke welded some angle iron to the underside that rests against the firewall to prevent the hood sliding back.
AEyssen
- First Name: Alex
- Last Name: Eyssen
TROG assigned Luke car/racer number 66 so it was time to get the livery painted on.
AEyssen
- First Name: Alex
- Last Name: Eyssen
Well Luke did it. Inspired by videos of prior years events, he set a goal to build a period correct Model T speedster in the manner a teenager would have done in the 20s or 30s. With limited resources and evolving skills, he built himself a car to be proud of and enjoy for years to come. The little #66 did great - he was the youngest driver, oldest car (only T actually) and the slowest. But the car performed great and it turned a lot of heads.
ewdysar
- First Name: Eric
- Last Name: D
- * REQUIRED* Type and Year of Model Ts owned: 1914 Touring, 1915 Speedster #32, 1916 Touring, 1927 Runabout
Well done!
Let Luke know that he is an inspiration to old duffers like myself. I am very impressed with the work that he has done and the dedication that he has shown in working towards his goals. Congratulations to Luke! And congratulations to the family support that has been provided. Good job, Dad!
Keep crankin',
Eric
Keep crankin',
Eric
AEyssen
- First Name: Alex
- Last Name: Eyssen
Less than 48 hours after making the return trip from
New Jersey to home base in the Carolinas, we had to get #66 to Texas for the annual Texas T Party. It would be the first time to show the little car to family and friends who have supported this project. The little speedster was a hit. And Luke set a new top speed much to the dismay of his elders.
