looking for push rods 10.25 long 1/4 ''
with cups on one end round on other end
thanks tom
1/4 push rods
Topic author - Posts: 35
- First Name: TOM
- Last Name: LEROUX
- * REQUIRED* Type and Year of Model Ts owned: 1915 speedster-1927 pick up
- Board Member Since: 2006
- First Name: Dodge
- Last Name: Riedy
- * REQUIRED* Type and Year of Model Ts owned: 1915 Ford Center Door
Re: 1/4 push rods
Smith Brothers in Redmond, Oregon can make you what ever you want.
- First Name: Kevin
- Last Name: Pharis
Re: 1/4 push rods
Almost all modern push rods are 5/16” or 3/8” tube, with same diameters for ball ends. I wound up making the 1/4” push rods for my Akron-Hed project from solid 4140 prehard rod (McMaster Carr), then oil quenched the ends. Working good with no noticeable wear issues so far. Also had to make double ball links to connect to the rockers from 5/16” rod, same hardening process.
- Last Name: Chaffin
Re: 1/4 push rods
Check out MANTON Pushrods in Lake Elsinore, CA. They have an online catalog with many options. Will make whatever you need.
