Door Garnish photos needed for part made out of unobtainium.
Does anyone have clear photos of the three metal garnish items on a coupe door, want top, front, and rear of door around the window glass. Since I cannot buy all three and want them to match, I might as well make them. We already have the two window sill metal garnish pieces. A photo of them installed in place would be great, how they interact if at all. I already have new square nuts and #10-32 oval head, slot drive stainless screws. Each garnish has three screw holes.
Thanks!
Topic author - Posts: 891
- First Name: Vernon
- Last Name: Worley
Vern (Vieux Carre)
- Last Name: Worley
Re: Door Garnish photos needed for part made out of unobtainium.
n/m I don't know what I am taking about. I finally found some photos and now realize that there are two brackets, front and rear of the door glass that support a U shaped garnish that slides down from the top.
Vern (Vieux Carre)
- Last Name: Humble
The 26-27 coupe door is the same as the 1928 Model A closed cab pick up door. For some reason the Model A guys have better reproduction parts than a lot of the T stuff available. They are available as reproductions by Snyders Antique Auto Parts.
- Last Name: Worley
Jeff,
Thanks, ordered the two garnish pieces and four brackets for Coupe from Snyder's. It was all in stock.
I also appreciate the window glass installation instructions in an old post.
Vern (Vieux Carre)
