FS: New 5 main short block with BB Rajo
Topic author - Posts: 92
- Last Name: Mahoney
New 5 main short block with Crower billet crank and rods. New Ross pistons, oil pump bracket and V-8 pump. Rajo BB head already done for block with new push rods, Chaffin intake manifold. Fronty side drive with water pump and parts to finish. Kirk Wright billet flywheel, new trans shafts, McEachern triple gears with needle bearings, ball bearing 4th main, etc. Asking $16,500.00 or reasonable offer, let's talk-must sell. Socal delivery available, other options negotiable. Have speedster chassis available for extra cost if you want a complete project.
Re: FS: New 5 main short block with BB Rajo
That's a beautiful bottom end!
- First Name: Michael
- Last Name: Peternell
- * REQUIRED* Type and Year of Model Ts owned: TT gas truck, T tractor conversions, '15 touring, '17 speedster, '26 16 valve speedster
- First Name: craig
- Last Name: leach
Michael, I'm thinking she was the only women in the line of sight, correct?
Craig.
Craig.
Where did that block come from? Burz?
Block was cast by Les Schubert in Canada. Super nice.
- First Name: Tom
- Last Name: Magee
- * REQUIRED* Type and Year of Model Ts owned: 1924 Speedster
Hi Mark,
I sent you an email.
- First Name: Lawrence
- Last Name: Blake
Mark. Any pictures and description of the chassis
Block is spoken for.
BB Rajo is available by itself for $3,500.00 obo.
Will get pictures of chassis posted hopefully later today.
- First Name: Dodge
- Last Name: Riedy
- * REQUIRED* Type and Year of Model Ts owned: 1915 Ford Center Door
That was quick, I had't finish buying my lottery tickets yet.....
Larry. Sent you a PM.
Speedster chassis: new low radiator with Faultless style shell as commissioned by the great Howard Genrich, Mercury style front axle with Chevy spindles, Temco shocks and split wishbone to frame, new bucket seats, Neville steering wheel, original Warford and shortened driveshaft Ruckstell (both need inspection), new Torpedo gas tank, 5 new aluminum disc wheels, and a lot more small stuff. Thinking $7,000.00 as a starting point. Let's talk
Forgot to mention new front hubs with bearings, new rear hubs, new set of McEachern safety hubs.
Rajo is spoken for.
