Body to Chassis Pads
Topic author - Posts: 58
- First Name: Campbell
- Last Name: Tellman
- * REQUIRED* Type and Year of Model Ts owned: 1916 Ford Touring
Hey All,
After removing the body to repair it I now cannot remember where the pads go. I have new dust shields and I don't see much info in the Ford Service Manual.
Can anyone advise me?
Thanks,
Campbell Tellman II
1916 Ford Touring Car
Beaufort, NC
Thanks,
Campbell Tellman II
Beaufort, NC
- First Name: Erik
- Last Name: Johnson
Re: Body to Chassis Pads
When your 1916 touring originally came from the factory, there were no pads between the body brackets and the chassis.
If there were pads when you removed the body from the frame, those would have been added by someone at a later date.
- First Name: Jeffrey
- Last Name: Hausey
You may have had shims to adjust door openings.
- Last Name: Aldrich
- * REQUIRED* Type and Year of Model Ts owned: 1915, 1923. 1927
I used an old inner tube that I cut up and used between the body brackets and the frame on my 1915. No noise at all...Erik Johnson wrote: ↑Thu Aug 14, 2025 2:15 pmWhen your 1916 touring originally came from the factory, there were no pads between the body brackets and the chassis.
John Aldrich
Typical Model T Addict
Hot rodders use them to reduce vibrations. Old tubes work too
- First Name: Shannon
- Last Name: Helm
Thanks to all that responded. I looked at the pads today and they are about 1/2 inch thick rubber. There is a longer pad under the radiator. I have done a lot of work on the body and the doors are perfect. I will check the frame rails to see if I need the pads to keep the body level.
Campbell Tellman II
1916 Ford Touring
Beaufort, NC
Campbell Tellman II
1916 Ford Touring
Beaufort, NC
Introducing a 1/2" pad under the body would necessitate raising the radiator too so the hood would still fit. !/2" is overkill. If the aim was to stop noise/squeaks 1/8" would do. Best to use insertion rubber with the fabric in the rubber That said the only place I have ever used any rubber is under the pan ears on just one of my Ts.
As others indicated, sometimes shims are used on the frame mounts to adjust door gaps. The need to do so indicates the frame is no longer straight.
- First Name: Erik
I would skip installing rubber pads or shims.
