Anyone have a spare 1915 rear radius rod? The threads on one of the rods on my car are stripped.
Phil Jamison
Seeking 1915 Rear Radius Rod
Karl Von Neumann
- First Name: Karl
- Last Name: VonNeumann
- * REQUIRED* Type and Year of Model Ts owned: 1916 touring 1927 tudor 1926 hotrod 1913 speedster (project) 1926 coupe (project)
- Board Member Since: 2022
Re: Seeking 1915 Rear Radius Rod
Is it a cast iron end on the diff side you should probably just repair it it will be cheaper
Phil, yours is repairable if you want to go down that track. The worn section can be built up with weld, then ground/filed back into round. The good thread on the end gives you a lead-in to then use a die to make a new thread.
I have found 2 or 3 variations in the length of the round section of those rods, so finding a matching one, if that is important to you, may be a little frustrating.
Allan from down under
mortier
Topic author - Posts: 102
- First Name: Philip
- Last Name: Jamison
- * REQUIRED* Type and Year of Model Ts owned: 1915 Roadster
I found a radius rod at Lang's, but I'm also attempting a repair of my old one. If that works, I'll post some photos.
Phil
Phil
mortier
My MIG repair worked well. Though not a concours winner, it's plenty strong.
Phil
Phil
Doesn't have to be strong. Filling the worn spot just tightens the potential movement if loose.
Did you deal with the corresponding wear in the DS tube?
mortier
I rebuilt the rear, so I think the driveshaft should be OK.
