ISO: EE Model T crank preferably already ground, ready to go
nathanw90
First Name: Nathan
Last Name: Warburton
Post by nathanw90 » Tue Sep 09, 2025 10:40 pm
Might be in the market to replace my crank. Putting a feeler out for something stronger than what I've got. Rear flange out 2 thou. Could just need a facing, could be worse. Would like to upgrade for longevity anyways.
Trying to stay in budget (I know, those new fancy ones at Chaffins..)
Let me know what you have!
Thanks!
tman1913
Last Name: Bender
* REQUIRED* Type and Year of Model Ts owned: 1913 Canadian touring, 1924 Roadster, 1926 Mercury speedster, 1927 Roadster p/u, 1920’s bobtail dirt track racer
Re: ISO: EE Model T crank preferably already ground, ready to go
Post by tman1913 » Wed Sep 10, 2025 11:54 am
I have a EE crank extra to my needs. Mag checked ground, mains 1.226”. Rods 1.233”. Flange trued both sides $300.00 plus You pay freight and packing.
Mike Bender
Tulsa Ok
PM via the forum perfered
nathanw90
First Name: Nathan
Post by nathanw90 » Wed Sep 10, 2025 1:05 pm
Mike Bender
Tulsa Ok
Mike, sounds excellent. My current setup is a ground 20/20 under.
Can I get away with adjusting shimming to avoid line boring?
tman1913
Last Name: Bender
Post by tman1913 » Wed Sep 10, 2025 1:16 pm
You should have shared that info to begin with.
Nope will not work with out new Babbitt and line bored.
Mike Bender
Post by speedytinc » Wed Sep 10, 2025 1:42 pm
I disagree. Already 20 under. +wear?? Offered crank is only .002" larger. Very doable with timesaver.
Bonus: the new bearing surfaces will be 100%.
I have done the same, fitting a 1.250 scat crank to a standard Babbitt block.
I would not pass up this excellent crank.
