Hassler spring install
Topic author - Posts: 79
- First Name: William
- Last Name: Reep
- * REQUIRED* Type and Year of Model Ts owned: 1924 roadsters, 1926touring
Hello all, after the rebuild of a friend's rear axle we're having issues putting the springs in place. I wasn't involved in their removal so I didn't see how he got them out. This is on a 1920 touring with, what I'm told, is a California top. He has it on a lift which is a difficult install operation for me, I'm used to working on the floor. We've tried compressing them and wiring them, can almost get it but no cigar. Does anyone with experience in Hassler springs have a recipe method of install. We thank you for your support, Wingnut
- First Name: Erik
- Last Name: Johnson
Re: Hassler spring install
Hasslers came with a dedicated tool to compress the spring. However, you can compress the spring with it in the bracket with a homemade version using a piece of threaded rod, two nuts, a washer and a flat piece of steel with a hole drilled in it as I described here:
https://www.mtfca.com/discus/messages/1 ... 1281825166
And here:
https://www.mtfca.com/discus/messages/4 ... 1398691007
And here:
Instructions +Wingnut wrote: ↑Sun Sep 14, 2025 9:31 amHello all, after the rebuild of a friend's rear axle we're having issues putting the springs in place. I wasn't involved in their removal so I didn't see how he got them out. This is on a 1920 touring with, what I'm told, is a California top. He has it on a lift which is a difficult install operation for me, I'm used to working on the floor. We've tried compressing them and wiring them, can almost get it but no cigar. Does anyone with experience in Hassler springs have a recipe method of install. We thank you for your support, Wingnut
And there's more
- First Name: Erik
If you make a tool yourself, it doesn't have to be as complicated/fancy as the Hassler factory issue tool.
As I posted above, a length of all-thread, two nuts, a washer and a flat piece of steel with a hole drilled in it will suffice to compress the spring in the bracket.
- Last Name: Reep
Thanks , we'll give it ago with a home made version. really appreciate it . Wingnut
As a safety precaution. have some kind of strap around a spring coil & the base its being attached to in case the the tool slips.
A good place for heavy nylon tie straps !
