26/27 Bed crossmember cover plate
351cmach
Topic author - Posts: 34
- First Name: Robert
- Last Name: Durgin
- Board Member Since: 2014
I have a 26 pickup and can't figure out why the crossmember cover plate is proud of the bed boards. The crossmember is up against the cover now so you can't move the cover lower. Are the body blocks incorrect?
Re: 26/27 Bed crossmember cover plate
That 'hump plate' should be mounted with the flanges under the bed wood. Suppose the wood blocks are misplaced, can't seem to see in the photos.
Hump plate on originals:
351cmach
- Last Name: Durgin
unfortunately, I can't mount it with the flanges under the bed wood. The crossmember is already up against the hump plate. bocks? Do you mean blocks?
What blocks are you referring to?
- First Name: Jeff
- Last Name: Humble
- Board Member Since: 2006
Can you post some pictures of the outside view of the turtle deck sub frame please.
Jack Putnam, in Ohio
- First Name: Jack
- Last Name: Putnam
Why not raise the bed 3/4 of an inch with new wood blocks.??
Meant to post "body blocks" they are frame mounts to lift the runabout body and its deck off the frame. You might have missing or worn ones, and the body is mounted too low on the frame.
Raise the bed, put the plate where it belongs, and oil the springs.
351cmach
- Last Name: Durgin
That's what I was thinking but didn't know if something else was off. The hood alignment seems good though.Jack Putnam, in Ohio wrote: ↑Fri Sep 26, 2025 9:49 amWhy not raise the bed 3/4 of an inch with new wood blocks.??
It looks like the body and rear subframe are about where they should be, but the bed is too low. I'm not sure just where is the problem lies. The fenders seem to be in the right place relative to the running boards and the bed. Maybe all the wood blocks are too thin, including the running board blocks, and the entire body is too close to the frame.
- First Name: Jeff
- Last Name: Humble
Everything looks right but it does not add up... I am starting to think your floor boards are too thick, that would bring the cover plate lower and therefore closer to the frame. Please measure the thickness of the floorboards and report back.
351cmach
- Last Name: Durgin
My thoughts also, something doesn't seem to add up. I thought about the board thickness but everything else lines up. (see the pics). The boards measure 3/4".
Mark Nunn
- Last Name: Nunn
Is this a Canadian-made truck? For some reason I was thinking that frames for the UK market had taller rear crossmembers to lower the car. Where did I get that impression?
Just another observation from your photo. The crosssmember on your pickup is the earlier version without the flanges for reinforcement. But both have the same curve.
Believe you have enough space under the crossmember and the bed to place the hump place flush with the bed wood.
There is only a little space anyway between the hump plate and the top of the crossmember.
That is why Ford used the hump plate, otherwise the bed boards would ride on the very top of the radius of the crossmember, making fit difficult.
Could just be the former owner didn't know the flanges of the hump plate mount to the underside of the bed boards.
351cmach
- Last Name: Durgin
Nope that's the issue I have.
No room. Maybe I need new body blocks but the few I have seen in person sit the same as mine. Things don't add up, but I'm sure we'll get to the bottom of it.
The pictures of the bed & fender (especially #3) look like the bed is to low & the fenders bent down to fit.
Well looked again and see now the bed wood isn't like stock install. Yours has 6 metal bed strips or cleats. The factory is 4. The curved metal bed sides hold the edges of the outer boards. These use carriage bolts thru the curved bed sides.
So that may be the problem.
Here is the factory install of the bed boards and using only 4 bed strips. 2 short and 2 long.
Oldrusty26
- First Name: Travis
- Last Name: Melnick
- * REQUIRED* Type and Year of Model Ts owned: 26 Rpu 27 Tudor 25 TT etc...
- Board Member Since: 2012
May be sacrilege but I left my cover out , relief cut the boards to make a smoother look
The board thickness is really 13/16", at least it is on a 1925. Take your bed off, and put in the plate correctly. You will be happy you did.
351cmach
- Last Name: Durgin
I'd love to but no room, hence my dilemma. Just trying to figure it out before tearing it apart.Original Smith wrote: ↑Fri Oct 03, 2025 1:53 pmThe board thickness is really 13/16", at least it is on a 1925. Take your bed off, and put in the plate correctly. You will be happy you did.
varmint
- First Name: Vernon
- Last Name: Worley
1) Before completely tearing it down you could remove the cover plate and then with a straightedge show that it protrudes above the wood surface.
2) With a long straightedge, underneath the car, measure the rise of the hump above the sill, where the wood rests. Good luck getting someone to give you their measurement. If it's the same as our improved Coupe, I'll help.
Vern (Vieux Carre)
It appears the rails were replaced, and when they did that they didn't redrill the holes correctly?
