Engine oil
Jim Byrne
First Name: Jim
Last Name: Byrne
* REQUIRED* Type and Year of Model Ts owned: 1917 model t
Engine oil
Post by Jim Byrne » Wed Oct 01, 2025 11:08 am
I am a new 1917 T owner and want to know what the best choices are for engine oil and coolent
Re: Engine oil
Post by speedytinc » Wed Oct 01, 2025 11:22 am
My preferences.
Valvoline racing 30 wt. Any good detergent 30 wt will do.
Water soluble oil for the radiator in distilled water. Sold @ auto parts stores as "anti rust & water pump lube."
Buckle up. Many opinions coming.
Re: Engine oil
Post by TXGOAT2 » Wed Oct 01, 2025 12:10 pm
Ford recommended what amounts to 20W, but what did they know about Model Ts?
Last Name: Humble
Board Member Since: 2006
Re: Engine oil
Post by Humblej » Wed Oct 01, 2025 12:47 pm
10w 30 oil and 50/50 conventional coolant.
big2bird
First Name: Jeffrey
Last Name: Hausey
Re: Engine oil
Post by big2bird » Wed Oct 01, 2025 1:07 pm
My preferences.
This^^^^^^^
Charlie B in N.J.
First Name: CHARLIE
Last Name: BRANCA
Board Member Since: 2010
Re: Engine oil
Post by Charlie B in N.J. » Wed Oct 01, 2025 1:28 pm
As stated: 10W 30 oil and 50/50 coolant. Don’t bother with non detergent 30W. Gets too heavy in winter. Experience talking here.
Re: Engine oil
Post by John kuehn » Wed Oct 01, 2025 3:07 pm
Save your money and go to Wal Mart, Auto Zone, Oriellys and buy their store brand 10w30, or 10w20 HD oil. It’s much better than oil Ford ever put in Model T’s.
love2T's
First Name: T
Last Name: Gates
Re: Engine oil
Post by love2T's » Thu Oct 02, 2025 9:32 am
John, Menards (we pronounce it "MAYnerds ha ha) actually has Rotella 10w30 usually for LESS than the "off brands" at auto stores. You can't beat the quality of Rotella. And if you're concerned about zinc and phosphorous it's still got the highest levels "allowed".
Jack Putnam, in Ohio
First Name: Jack
Last Name: Putnam
Re: Engine oil
Post by Jack Putnam, in Ohio » Thu Oct 02, 2025 9:56 am
But whatever detergent oil that is on sale, it will be better than what was available a 100 years ago.
babychadwick
First Name: Chad
Last Name: Azevedo
Re: Engine oil
Post by babychadwick » Fri Oct 03, 2025 9:22 am
10w40 here, but then its a hotter engine with an oil pump where I'm not dependent on the Ford splash system. In the past coolant has just been water as it leaked out so fast there was no point in antifreeze. With the new radiator (something needed for the past 40 years) and rebuilt water pump I can now run 50/50
CatGuy
Last Name: Hunt
* REQUIRED* Type and Year of Model Ts owned: '26 Runabout
Re: Engine oil
Post by CatGuy » Fri Oct 03, 2025 10:32 am
How much of an effect does the different weight of oil have on the transmission function? Any?
Rich P. Bingham
First Name: Rich
Last Name: Bingham
Re: Engine oil
Post by Rich P. Bingham » Fri Oct 03, 2025 11:17 am
Viscosity affects clutch function. Heavy (cold) oil will cause the car to creep in neutral.
Get a horse !
Re: Engine oil
Post by TXGOAT2 » Fri Oct 03, 2025 12:31 pm
Model Ts are designed to use what Ford called "light cylinder oil", which is about 20W. Ford recommended a quality "Light" oil for general use, and recommended a light oil mixed with 10% kerosene in cold weather. The lubrication system will not function as it is supposed to with thick oil, and neither will the clutch and bands. Thick oil might also contribute to problems with triple gear bushings, and it will make starting more difficult. Thick oil will interfere with roller timer function, especially in colder weather.
For a stock or near-stock T engine, a good 10W30 is an excellent choice. In cold weather areas, 5W30 or 5W20 is a good choice. There is no good reason to put thick oil in a Model T, and a number of good reasons not to.
Re: Engine oil
Post by Original Smith » Fri Oct 03, 2025 1:35 pm
I like Valvoline oils. I use 15-40, 10-40, 10-30. They all work fine here in Southern California.
