T-2335 Ford Cylinder head Wrench
Topic author - Posts: 1501
- First Name: Terry
- Last Name: Woods
Correct me if I'm wrong, but I think Ford supplied TWO different wrenches that fit cylinder head bolts, one that had an open end on one end and a closed box end on the other end. Then there was another wrench that had a closed socket type end on one end and an open end on the other end. Which type is T-2335 ?
- First Name: Joseph
- Last Name: M
Re: T-2335 Ford Cylinder head Wrench
This link might help:
https://www.mtfca.com/discus/messages/5 ... 1430496170
They are both T2335, the one with the socket end for head bolts is 1913/1914 till about 1920 and the box end is till the end of production.
- First Name: Terry
- Last Name: Woods
Thanks, Pep.Pep C Strebeck wrote: ↑Sat Oct 04, 2025 7:10 pmThis link might help:
- First Name: Erik
- Last Name: Johnson
The same wrench is used for loosening demountable rim nuts.
Maybe the revision to box-end may have something to do with the above?
PS: Has anyone ever seen a nickel-plated T-2335 wrench? I go to a lot of estate sales in the Twin Cities and saw one but passed on it because the open-end was spread out. I can't remember if the other end was socket or box-end.
